what is this motor?
what is this motor?
Postby kingcorolla » Wed Jan 12, 2005 9:55 pm
hey guys
so anyway, on my missions, i found a truck chassis, a TOYOTA truck chassis infact. And i wanna know what motor its equiped with, so then i can identify the g/box etc.
its a 4 cylinder PETROL engine, in/ex on same side, VERY similar to a K series motor, (ie dizzy, fuel pump same location, water system identical)
hmmm, i also noticed the oil is cooled via the radiator, ahh, oil filter facing DOWN (under manifolds), anything else anyone needs to know i can easily get.
heres some pics
http://img94.exs.cx/img94/2581/mvc042f5oo.jpg
http://img92.exs.cx/img92/5114/mvc043f9bz.jpg
http://img92.exs.cx/img92/4687/mvc044f0ma.jpg
thanx
1983 Carina AA63 4age
kingcorolla
Postby wde_bdy » Wed Jan 12, 2005 10:26 pm
Can you find the engine number?
I suspect it is an R series.
Callum
wde_bdy
Postby Mr Revhead » Wed Jan 12, 2005 11:39 pm
i suspect its a "y" engine
Postby wde_bdy » Thu Jan 13, 2005 12:36 am
http://www.japparts.com.au/Pics/Thumbs/4yth.jpg
There is a pic of a 4Y, but distributor appears to far forward compared to the pics above. Having trouble finding an R motor pic.
Callum
wde_bdy
Postby kingcorolla » Thu Jan 13, 2005 8:12 am
ye ive worked on a 4y before, and its not a y motor.
the thermostat is on the hot water outlet, same a k motor, not same as a y motor.
ill have a geez at the block today and see if i can spot an engine number
kingcorolla
Postby Mr Revhead » Thu Jan 13, 2005 8:44 am
12rj from something like a rh24 hiace truck
or maybe 5r from ru2#/3# dyna/toyoace
Postby kingcorolla » Fri Jan 14, 2005 1:03 am
cool thanx warwick.
im assuming its a W box, but i think its variable ratio :x
but could be wrong, its wasnt a large truck.
Plus the rear axle is fuken humungous, and could be too big to transplant without serious modification 8O
And its a hydraulic-drum brake setup which is a bonus, as opposed to air brakes.
kingcorolla
