gear box flush?
gear box flush?
Postby phatman3801 » Thu Jan 13, 2005 10:47 am
hey im going to change my gearbox oil as my gears are grinding quite a bit! as its been grinding heaps there will be heaps of shit in the oil so i wanna drain and then flush but dnt no how to flush? wot should i use to flush the gearbox?
phatman3801
Postby snwtoy » Thu Jan 13, 2005 11:29 am
Don't know if there's such a thing as gearbox flush.. If you can afford it, buy two lots of oil, replace the first lot, drive for some distance, then replace with the final lot. That should get rid of most crap.
snwtoy
Postby Twolitre » Thu Jan 13, 2005 12:54 pm
Chances are you will have a magnetic drain bolt on your gearbox, if you take it out to drain the gearbox you will notice that it will have metal particles stucke to it so obviously give it a thorough clean before you put it back in and no need to flush, just drain it while the oil is warm, ie. after a drive.
Twolitre
Postby Inane » Thu Jan 13, 2005 2:10 pm
Some places have machines that do actually flush the gearbox,
around a hundy to have it done.
Inane
Postby Twolitre » Thu Jan 13, 2005 3:29 pm
Inane wrote:Some places have machines that do actually flush the gearbox,
I'm pretty sure those machines are primarily designed for flushing automatic transmissions.
Twolitre
Postby Inane » Thu Jan 13, 2005 3:43 pm
True, I was making an assumption.
Inane
