4age in kp60
4age in kp60
Postby 4agtepwr » Thu Jan 13, 2005 10:17 pm
Hey i have a little kp60 that im in the throws of putting a blue top 4age in. The engine is mounted and im just wondering wat arangment ppl use for the clutch ie cable or hydraulic? how did u mount your master cylinder etc and wat master cylinder did you use?
4agtepwr
Postby matt dunn » Thu Jan 13, 2005 10:28 pm
All those questions depend on what gearbox you are using?
Matt
Postby 4agtepwr » Thu Jan 13, 2005 10:53 pm
sorry im running a t50
4agtepwr
Postby 4agtepwr » Fri Jan 14, 2005 10:58 pm
bump :)
4agtepwr
Postby thaphatty » Fri Jan 14, 2005 11:18 pm
use master cylinder from ae86
thaphatty
Postby l1ttle_d3vil » Sat Jan 15, 2005 12:59 am
i got an ae86 slave and a ae82 master cylinder on mine...
Re: 4age in kp60
Postby fangsport » Mon Jan 17, 2005 6:11 pm
4agtepwr wrote: The engine is mounted and im just wondering wat arangment ppl use for the clutch ie cable or hydraulic? how did u mount your master cylinder etc and wat master cylinder did you use?
fool, it is bloody difficult to mount the clutch system into the KP after the motor is in, in fact it took me at least 3 times longer to do.
for the cost of the 2 cylinders, buy new ones, because once fitted it WILL be a nightmare to get to .
we used a TA Celica pedal mounted to the side of the pedal box. a bracket was needed to brace the pedal and a spacer was made to stop the brake pedal from moving side-to-side. there is a pressing in the bulkhead that is almost the same shape as the flange on the master clyinder that lined up perfectly for us.
fangsport
