Downpipe and engine check light
Postby MyXsPtLk » Mon Jan 24, 2005 11:33 pm
Hey I just got my mechanic to put an Aussie dp on my gt4, and everything's done up good, the car goes great (very very nicely) and sounds much better, only problem is now the check engine light is on. He doesn't understand why either. The o2 sensor is on properly, he says there was some sort of cat temperature sensor but I've never heard of one? Is this right? And he showed me this plastic connector which was supposed to have been plugged into the factory dp but again I've never heard of that and seeing the condition of the connector (still in normal shape) I don't think it would have been anywhere near the cat cos wouldn't the heat from the factory dp just have totally melted it to nothing?? Anyway, anyone there ever have this problem?? Or any idea what's wrong with it? The car still runs normally, boosts fine, idles fine, starts fine, stops fine. Just the damn light. It's bugging me. Thanks for any info guys
Ben
MyXsPtLk
Re: Downpipe and engine check light
Postby CozmoNz » Tue Jan 25, 2005 12:02 am
MyXsPtLk wrote:Hey I just got my mechanic to put an Aussie dp on my gt4, and everything's done up good, the car goes great (very very nicely) and sounds much better, only problem is now the check engine light is on. He doesn't understand why either. The o2 sensor is on properly, he says there was some sort of cat temperature sensor but I've never heard of one? Is this right? And he showed me this plastic connector which was supposed to have been plugged into the factory dp but again I've never heard of that and seeing the condition of the connector (still in normal shape) I don't think it would have been anywhere near the cat cos wouldn't the heat from the factory dp just have totally melted it to nothing?? Anyway, anyone there ever have this problem?? Or any idea what's wrong with it? The car still runs normally, boosts fine, idles fine, starts fine, stops fine. Just the damn light. It's bugging me. Thanks for any info guys
Ben
look at the old downpipe... is that the ONLY thing he touched?
if so look where the sensor hangs from that area, is it directly under the car, or moreso near the gearbox etc? any chance of pix, im sure once you put a pick up someone will go *OI! thats for the bla temp*.
etc :). just thought id try help :(
Rayne For President!
CozmoNz
Postby BR0Z » Tue Jan 25, 2005 8:25 am
Have you done the diagnostic (spelling?) check to find out what the fault code is?
Do a search on the board & you should be able to find the codes and how to run the check. You have to open the small 'diagnostic' box under the bonet near fire wall passenger side then using a small wire bridge 2 of the terminals - can't remember which ones, then once ignition is on the dash light will come on & off (like morse code) & give you a number which then can be checked against the fault list.
Hope that lame description is of some help. :?
By the way what was the cost of the Dump Pipe?
Cheers, Mark
Oldie but goodie
Mark Bros
91 GT FOUR RC x 3 1 Red (mine) Daniel - 2 White - 1 damaged & for sale =(
May the FOURce be with you
http://toyspeed.blakjak.net/profiles/profile.php?id=244
BR0Z
Postby Al » Tue Jan 25, 2005 11:30 am
the terminals to bridge are te1 and e1, you just turn the ignition to on with a paperclip/wire bridged across the two terminals and count the flashes, i dont have a cat temp sensor anymore, my mechanic just grounded mine when he fitted my Aussie dp.
btw BROZ they are $450aud + $35aud airfreight, takes like 2 days.
Al
Postby BR0Z » Tue Jan 25, 2005 12:05 pm
Damn I wish they were cheaper :cry:
Oldie but goodie
Mark Bros
BR0Z
Postby MyXsPtLk » Tue Jan 25, 2005 4:34 pm
Al wrote: i dont have a cat temp sensor anymore, my mechanic just grounded mine when he fitted my Aussie dp.
Do you have any idea how he did that? Would I be able to do it myself?? How do i know which wire to ground?
MyXsPtLk
Postby Al » Tue Jan 25, 2005 4:43 pm
I'd check your codes first. 8)
Al
