Charged1 wrote: there is a guy on ebay selling sc12 seal kits that im thinking about at the moment
Mr Revhead wrote:remember the oil ONLY lubes the gears.... not the screws... so losing oil shouldnt affect your boost.... except by extra drag from worn gears...
superchargers work to very fine tolerances, you will need to find a place experienced with such things if you want a good job.
as stated above that kit isnt a toyota item, if fact toyota list the screws and gear assembly as one part
ndeany wrote:Mr Revhead wrote:remember the oil ONLY lubes the gears.... not the screws... so losing oil shouldnt affect your boost.... except by extra drag from worn gears...
I'm having issues with my supercharger atm. I'm running a 180mm crank pulley, modified water pump, and tensioner. It sounds like the bearings are f***ked in my supercharger. I've tried 2 other superchargers and 1 other clutch. But no joy with any of them. What is the gear assembly worth from you guys??
ndeany wrote:what is one of those worth??
