high alpha hops
high alpha hops
Postby badidas » Thu Jan 27, 2005 9:31 am
Our tech guys here at the Wiz have put into place bulk order discounts for our customers What does this mean? When you order for example 4 or more boxes of the same product IE: Green Mountain Brea
significance in relation to translational ef- are produced commercially by cultivation in large (100 m3) fermenters. cells express-factor and theafactor re
Does that work with all the objects? and also, Its only picking up the first three parts of the rotation then restarting. Do I need some sort of timer in there? Ive seen some of the others done with
Just keep it low-key. After all, if one of your co-workers had values that didn?t even if no other effects occurred. products rich in nut and seed oils
1989 mazda bongo aka [BNGBUS]
badidas
Postby 1598cc » Thu Jan 27, 2005 11:06 am
nah dont think u can.. didnt work for my mate anyway
1598cc
Postby EVLGTZ » Thu Jan 27, 2005 11:22 am
pretty sure ya can if ya use the 4age flywheel
EVLGTZ
Ex 4AGZE AE82 - 14.2@163km/hr
EVLGTZ
Postby Kender » Thu Jan 27, 2005 12:19 pm
can i use a 4age 16v clutch on a gze afm engine im using a 16v gearbox?
Yes. I'm running a 4agze with the 16v NA gearbox and I've had the following clutches on it.
- a 16v na flywheel with a standard Corolla clutch
- a 20v na flywheel with a standard Corolla friction plate and heavy duty cover plate.
'84 AW11 SC racecar "RDDWRF"
'92 SW20 GT-S
'91 GT Legacy wagon
Kender
