i no some one who says his vvt pully is $$%. vvt dusnzt work at all. its in a ae101. he dropped it down a gear or so when he was doin 160kmph.
and says it broke or snapped of or summint. what acctual breakes??? is it a cam pully or wat??
fivebob wrote:Could've gone 5th - 2nd![]()
I've done that once on a rental Ford Escort, lots of smoke from the tyres and the tacho needle bouncing off the stops, didn't break anything tough... damm sh*tty Ford gearboxes
CozmoNz wrote:A) the Trueno and Levin gearsets can pull 180ish in 4th gear... so *dropping down* a gear, is useless..
BZG|Bling wrote:CozmoNz wrote:A) the Trueno and Levin gearsets can pull 180ish in 4th gear... so *dropping down* a gear, is useless..
last time i checked 4th did more than 180 (at less than rev cut), so where did u work that one out? or u just making stuff up again?
AceSniper wrote:Dont forget 91-91 20v's have the C52 with slightly longer ratio on two of the gears.
CozmoNz wrote:AceSniper wrote:Dont forget 91-91 20v's have the C52 with slightly longer ratio on two of the gears.
only 1 year
obviously you mean 91-94. ae101. but i did not know that. what gears, and what speeds etc.
