warning light in ae101
Postby Mike- » Wed Feb 02, 2005 11:27 am
a warning light keeps on coming up in my car and i dont know wat it is
its the last lite on the dash under the check engine lite, it is a picture of a car with lines coming out the back, any idea of wat this is?
Thanks
Mike-
Postby Mr Revhead » Wed Feb 02, 2005 11:28 am
you have brake/taillights that are not working
Postby Mike- » Wed Feb 02, 2005 12:01 pm
do you think it could be that the oil warning is wired up to that lite coz my oil was fukin low and the oil light never came on coz my backlightsd all work
Mike-
Postby aesc » Wed Feb 02, 2005 12:17 pm
Not likely to be oil as that has its own warning light.
Maybe you have a wiring fault which is causing the light to come on even though all your bulbs are ok.
But I suspect that one of the bulbs is out. Have you tried checking all bulbs when you have brakes on, and brakes on when headlights on etc?
EX AE101 owner
2013 Ford Focus ST
aesc
Postby TruenoBoy » Wed Feb 02, 2005 1:03 pm
Your brake fluid is probally low dude
TruenoBoy
Postby Mr Revhead » Wed Feb 02, 2005 2:22 pm
its the brake/tail LIGHT warning light......
Postby toyonut » Wed Feb 02, 2005 3:02 pm
dont get complicated yet, listen to mr revhead, check your back lights at night so you can see them all clearly, one will be blown but it can be hard to tell sometimes.
toyonut
Postby Charged1 » Thu Feb 03, 2005 6:54 pm
Hi mate , yeah I have the same light stuck on too , on my 92 GTZ , at first it was a brake light , changed that and still the light stays on , all my my tail lights are find now so just ignor the warning light now ???
Charged1
Postby Mr Revhead » Thu Feb 03, 2005 8:18 pm
it is possible for the warning light to be on while all lights still working... it happend on my ae82 sprinter. i just replaced bulbs till i found the one that caused it. electrics are beyind me so ill let a sparky explain it
or you coul dhave a wiring fault
Postby matt dunn » Thu Feb 03, 2005 10:58 pm
Mr Revhead wrote: electrics are beyind me so ill let a sparky explain it
OK then,
the checker relay measures current flow through the bulbs to determine if they are all working. If not enough current, it brings on the fault light.
When the stop/tail bulbs get old they draw lees current than they used to and sometimes can drop below the limit.
Solution, replace all the stop tail bulbs ( probably 4 at $2 each)
that will fix it.
Matt
Postby toyonut » Thu Feb 03, 2005 11:00 pm
damn dont have the levin any more but, is the light off when you first start the car?. Mine was and it came on when you pressed the brakes, so i replaced the bulb and no more light came on. might work the same way if you get the light only when turning on the lights. otherwise you have a wiring fault and may need to see a friendly auto sparky
toyonut
Postby kingcorolla » Thu Feb 03, 2005 11:01 pm
could be a brake fluid warning light, some have sensors on the resovoirs to indicate a low level. his description sorta fits this...
could help if you tell us what car you drive... :roll:
even better, just check dam the brake fluid level. then you can eliminate that option if its full. throw us a fukn bone.
1983 Carina AA63 4age
kingcorolla
Postby matt dunn » Thu Feb 03, 2005 11:32 pm
kingcorolla wrote:could be a brake fluid warning light, some have sensors on the resovoirs to indicate a low level. his description sorta fits this...
That brings on the handbrake light.
Matt
Postby Mr Revhead » Fri Feb 04, 2005 8:44 am
cheers sparky :D
Postby 85AW20v » Fri Feb 04, 2005 9:58 pm
hey kingcorolla - isn't ae101 like it says in the subject line enough to tell you what sort of car he drives:?: :?: Like Matt says, resistance drops in the old bulbs so the warning light comes on, even if they are still working.
See ya
Simon
85 MR2 20v
85AW20v
Users browsing this forum: Bing [Bot] and 22 guests
