Loud Bang 4agze HELP PLEASE
Postby Charged1 » Fri Feb 04, 2005 3:51 pm
Help , was driving up the road today and the motor went Bang ! and then all this smoke came out of the exhaust , after that its making this loud as noise , have I blown a cyinder or something , would it be safe to drive to a garage or better to get towed , any ideas ?
Charged1
Postby smokabitabud » Fri Feb 04, 2005 3:58 pm
haha thats what happened to my prelude after i got my new car and decided to fuk it. mine threw a leg probly summin similar. check ur oil lvl and c if theres ne holes in the bottom of the motor
smokabitabud
Postby Charged1 » Fri Feb 04, 2005 4:40 pm
Oil full , no holes , Im guessing it piston , cylinder or head gasket ? but im no expert ???
Charged1
Postby Leon » Fri Feb 04, 2005 4:42 pm
get it towed to a mechanic who specialises in bangs.
Postby Dell'Orto » Fri Feb 04, 2005 5:09 pm
What kind of noise? What colour smoke?
Postby deaf_rattle » Fri Feb 04, 2005 5:11 pm
where abouts in aucks are you?
I may be able to come have a look if you like
(if out west)
Postby Fuct Munkey » Fri Feb 04, 2005 5:38 pm
my FXGT did that when i was push starting it, i have blown out one of the rear mufflers. might be the same thing. it had been repaired before, and i blew a hole in the side of it. but thats what ya get for having a factory exhaust thats done 404xxxkm. nice carbon build up to ignite.
Fuct Munkey
Postby Charged1 » Fri Feb 04, 2005 5:39 pm
Nah mate im not out west , up at Paremoremo , just out from Albany , but thanks anyway , question if it sounds like its banging the block is that a piston ?
Charged1
Postby Charged1 » Fri Feb 04, 2005 5:45 pm
Sounds like something internal hitting , was a cloud of white smoke
Charged1
Postby Dell'Orto » Fri Feb 04, 2005 5:51 pm
If its a constant deep knocking noise, then it'll probably be a big end bearing gone up the $&#$%.
Postby Charged1 » Fri Feb 04, 2005 5:53 pm
Yeah mate thats the noise , is this a major then , is the motor stuffed ?
Charged1
Postby Dr-X » Fri Feb 04, 2005 8:21 pm
Leon wrote:get it towed to a mechanic who specialises in bangs.
LOL :lol: That made me laugh so hard :lol:
Sounds like a big end.
Dr-X
Postby Dell'Orto » Fri Feb 04, 2005 9:00 pm
Charged1 wrote:Yeah mate thats the noise , is this a major then , is the motor stuffed ?
Yep, its pretty major, and yup, in that guise, that motor is toast. Get it towed to a mechanic, and they can fit new big end bearings and regrind the crank, or alternatively fit a 2nd hand engine.
With the availability of 4AGZE's being the way it, its probably gonna be easier to rebuild it 8O
Dont drive it anymore thats for sure, or you will have a ventilated block.
Postby Charged1 » Sat Feb 05, 2005 9:55 am
Thanks for your help mate , sounds like it may be cheaper just to put a 20v in , are there any other motors that you know may be able be put in without too many major mods haven to be done , cheers
Charged1
Postby thaphatty » Sat Feb 05, 2005 10:01 am
rebuild+turbo ;)
thaphatty
Postby Charged1 » Sat Feb 05, 2005 10:09 am
Hi how many grand do you think it would cost to do a rebuild and turbo
Charged1
Postby deaf_rattle » Sat Feb 05, 2005 11:14 am
$1k for all the work, if you can assemble, clean and pull apart yourself
probably need a crank grind and polish, new bearings to suit and may have to get your conrods resized.
probably need a bore hone as well
might as well do rings etc while you are at it
Postby levin_it_large » Sat Feb 05, 2005 11:16 am
depends how much time u got, i take it its a daily driver so u don't want 2 b away with it for long?
finding the parts unless u in the trade is the hardest part. if u have the skills 2 do it obviously it will be cheaper if u want a garage 2 do it it'll be a few g's!
levin_it_large
Postby craigt » Sat Feb 05, 2005 2:26 pm
I spent over 2k on my last freshenup on my gtz.
That was with bits at cost, but also included guides, 5 angle valve job,
waterpump all belts and tensioners, supercharger oil etc, the list goes on.
Mr Autosure picked up most of the bill!!!!
If it doesn't fit, force it.
If it breaks it needed replacing anyway!
AE101 4AGZE
KP60 4AGTE project
craigt
Postby 4AGTE » Sun Feb 06, 2005 8:56 am
Look around for a second hand motor. If you can find a guy who imports them he sells a motor for about 1200-1400 dollars.
By the sounds of it you have run a big end bearing and if its not too bad then will cost pritty close to 1k anyways if you canot do any mechanical work your self.
Get a second hand motor then take your time and re build that one and make it strong for turbo an lots of boost.
4AGTE
Users browsing this forum: Bing [Bot] and 18 guests
