round vs square ke70 lamps
Postby Mr Revhead » Fri Feb 04, 2005 4:11 pm
right lost the info i had on this, so to all you old school guys out there
what is needed to swap a square lamp ke70 to a twin round lamp one.
i think its:
grille
lamps
bonnet (?)
guards
how different are the guards? can it be panel beated to fit?
Postby Dell'Orto » Fri Feb 04, 2005 5:06 pm
Nah, I think the parts that go around the headlight are a totally different shape. Could chop them I spose :?
Pretty sure thats all you need though, the latch is the same.
Postby kingcorolla » Fri Feb 04, 2005 5:58 pm
yeea twin heady. :)
ben there done that. I tryed hacking it up to fit, with no avail.
You cant modify them to fit, you need both guards. Dont need the bonnet tho.
you also need the headlight surrounds :wink:
1983 Carina AA63 4age
kingcorolla
Postby pervert » Fri Feb 04, 2005 6:05 pm
Can this be done with mine? I'm guessing panels won't quite bolt up like they would on the sedans?
pervert
Postby kingcorolla » Fri Feb 04, 2005 6:14 pm
pervert wrote:Can this be done with mine? I'm guessing panels won't quite bolt up like they would on the sedans?
yea they do.
DO IT PERV!!!
kingcorolla
Postby MetalupYoAss » Fri Feb 04, 2005 6:30 pm
anyone seen a green wagon driving around devo/takapuna with the twin round lights? its a mate of mine.. i just got the slanty front on mine but looks pretty cool without the front bumper
MetalupYoAss
Postby pervert » Fri Feb 04, 2005 6:36 pm
yea they do.
DO IT PERV!!!
Isn't the bonnet on mine different though with the V shape? Are the guards the same? So just need lights, grille and guards?
pervert
Postby fangsport » Fri Feb 04, 2005 6:38 pm
the 80-82 can be swapped over reasonably easy but will need new holes drilled to mount the headlight unit. the grille and surrounds and valance(?) panel need to be swapped over.
the later ones would be a mission, but in saying that, i have 81 KE70 front and rear lights in my TE71, as well as bonnet, bumpers etc.
fangsport
Postby pervert » Fri Feb 04, 2005 6:40 pm
Anyone got any parts for the swap lying around by chance? :lol:
pervert
Postby Dell'Orto » Fri Feb 04, 2005 7:15 pm
Pm Harry Landkroon, he does.
Postby dskd » Fri Feb 04, 2005 9:09 pm
i have done mine and
dont need to drill any holes and u do need the small part of the loom that hooks them up and yes u do need the valvance
IM NOT GETTING LESS HAIR IM GETTING MORE HEAD
dskd
Postby fangsport » Fri Feb 04, 2005 11:40 pm
dskd wrote:i have done mine and
are you sure you don't need to drill holes to mount the headlight?
fangsport
