Difference between AW11?
Postby FST4RD » Fri Feb 11, 2005 9:37 am
Was there much difference between the supercharged and non super charged models?? Apart from the obvious, Ie motor, ecu, loom?? And also is it as easy as bolting the 4AGZE motor, loom and ecu into a non supercharged one??
1983 Mitsubishi Starion
1995 Subaru legacy GT SW
FST4RD
Postby Virtual Genocide » Fri Feb 11, 2005 11:05 am
Between the earlier aw's yes, they only had the C-50 gearbox aswell as a "tail happy" suspension setup, whereas the s/c models suspension had alot less oversteer because of the extra torque, Targa Tops, the C-52 gearbox, upgraded brakes, and the usual interior changes.
Phil
You can sum up the entire dream world of the motoring enthusiast in four words: "dont fence me in"
My Profile <----- check it out!
Virtual Genocide
Postby vvega » Fri Feb 11, 2005 12:45 pm
hmmm
sc has that n/a dosent
bigger brakes all round
differnt rear end setup
different hubs
diffrent drive axels
e series box instead of the c series
added rear sway bar and stiffer front one
differnt rear shock setup
differnt fuel pump
different throttle linkage setup
different plaxcement of air con and alternator
there a very different car
yes you can bolt one in....
but
it will still be a bit of work its not quite bolt in
ive only just done that myself :D
v
vvega
Postby deaf_rattle » Fri Feb 11, 2005 12:47 pm
hurry up and get it going wayne.
i want to see it
Postby 85AW20v » Fri Feb 11, 2005 12:49 pm
There are also differences in where the subframes bolt on. It can be done but is a bit of mucking around.
See ya
Simon
85 MR2 20v
85AW20v
Postby FST4RD » Fri Feb 11, 2005 1:35 pm
I've decided that the silvertop 20v is going to be a go'er i think, i know of a black top head and quad throttles coming up for sale in the near future... might be interesting
FST4RD
