The one that doesn't is not meant to connect to the ecu.
It will contain the wires for the temp and oil senders, probably the power feeds to the injectors and air con stuff. None of which is meant to goto the ecu.
There are only three pins on the third socket that need connecting to get the engine running. PM me your email and i'll send you a pic of which ones.
4ageflyer wrote:What people are saying is rite, the two that fit come from the engine the other plug that goes into the ecu cmes frm the dash loom and runs warning lights etc. The third plug you have comeing from the engine bay normally goes to behind the left hand kick panel to a plug board for aircon etc
l1ttle_d3vil wrote:ohhk so seeing as i dont have aircon is there anything else i need that plug for? [the 3rd one on the engine bay]
Users browsing this forum: No registered users and 61 guests
