minijrocks wrote:Hi, ive got an ae101 ss and the front right suspension is starting to squeak. it sounds like its coming from the top of the shock/spring setup
just woundering if anyone else has had this problem.
And also whats the cheapest option of getting rid of superstrut? ie. getting cheap adjustables and ditching the whole ss setup instead of replacing....
thanks
Crampy wrote:I've got the same as the first two guys. My one used to squeak a little and now it does it all the time. I figured it was the SS as well, but I'm pretty sure it's closer to nthe top of the shock. Might have to replace the shockies me thinks. Let me know your findings when you've had it checked out...
aesc wrote:Ok got my diagnosed today was the lower Super Strut arm/ball joint.
For all those who have just recently done the arm and still making noises then id suggest taking banga69's avice and checking the sway bar bushes
HZRDIZ wrote:Haha funny. My AE101 FX GT with S/S has just started doing this. Its more annoying than anything. Guess i'll take it in this week to get fixed. Ball park figure what it costs to get repaired/replaced? The part that is.
HZRDIZ wrote:Just rang the suspension place and theyve told me it could be the arm and that i needs to be reconstructed - soudns expensive. Hopefully its only a bush or ball joint. He says the ball joints are hard to come by thou... guts... Anyone else fix their problem?
