difference between ae85/ae86 diffs
Postby l1ttle_d3vil » Sun Feb 13, 2005 10:09 pm
is there any way at all to tell which is which? other than dropping the clutch and seeing which blows first? :lol:
Postby Zak » Sun Feb 13, 2005 11:23 pm
The ae86 one has disk brakes, I don't think the ae85 ones ever had disk brakes.
I don't know if the 86 ever had drums though :?
Zak
Postby l1ttle_d3vil » Mon Feb 14, 2005 7:50 am
the "ae86" diff that ive got has drum brakes. i was told it was the diffs that came out standard with LSD's that had disc brakes, whereas the non-lsd diffs had drum brakes.
Postby AE85.6 » Mon Feb 14, 2005 1:58 pm
not all AE86 rear ends are lsd's thou, they were factory optioned not factory standard, AE85 rear ends were all drum brakes and from memory are a 6.5" diff. AE86s have disc rear ends and i think are 6.75" some lsd some not, however i think a few did come out lsd and still had drums, well so im told i cant say ive seen one thou so i dunno how common they are
If you drink, and drift,
your a bloody lunatic
AE85.6
Postby JT » Mon Feb 14, 2005 5:03 pm
Most AE86's had disc rears but they made an AE86 GT version that had a drum rear end. Easiest way to tell is if we can see a photo of the casing where the drive shaft meets the diff, the top of the casings are different.
As ae85.6 says, this is not the case. Disc rear ends also came with an open diff and are more than likely what you'll find in one. Alot of the factory lsd's were taken from the ones that came into nz and used for rallying.
JT
Postby NZ_AE86 » Mon Feb 14, 2005 6:51 pm
To the best of my knowledge the only AE86 diffs that had drums were Ozzie assembled cars that had a single cam 4a engine! (Although I have seen Toyota do some odd things!)
If it is a true AE86/4AGE diff it will have discs. Although the diff head can be the same size and have drums so the discs will not affect strength.
Current rides;
1985 AE86 Race/Rally Car
1986 Levin GT
NZ_AE86
Postby l1ttle_d3vil » Mon Feb 14, 2005 9:44 pm
pics here.
Postby l1ttle_d3vil » Mon Feb 14, 2005 9:51 pm
i also got an ae86 LSD and it looks pretty much identical to the diff pictured above as far as i can see...
Postby l1ttle_d3vil » Mon Feb 14, 2005 9:53 pm
Postby thaphatty » Mon Feb 14, 2005 11:35 pm
i found with a ae85 open diff rear end the pinon flange bit was about 20-25mm shorter than a facelift non lsd ae86 diff. made the stretch easy peasy though.
thaphatty
Postby spencer » Tue Feb 15, 2005 4:02 pm
l1ttle_d3vil wrote:the "ae86" diff that ive got has drum brakes. i was told it was the diffs that came out standard with LSD's that had disc brakes, whereas the non-lsd diffs had drum brakes.
Thats a load of crpa there are heaps of open head disk brake t-series diffs around. and the diff in the pic looks like a ae85 unit
ms63 crown
spencer
Postby Rob_GTZ » Tue Feb 15, 2005 4:43 pm
NZ_AE86 wrote:To the best of my knowledge the only AE86 diffs that had drums were Ozzie assembled cars that had a single cam 4a engine! (Although I have seen Toyota do some odd things!)
As already mentioned earlier in the post, In Japan AE86 Coupe's were available in a 'GT' model, they had AE85 Seats & a Drum brake rear end on them
Rob_GTZ
Postby NZ_AE86 » Tue Feb 15, 2005 6:30 pm
I have been thinking about this and unless I saw one I would not believe that any AE86 that had a factory fitted 4AGE came with drums.
I can read that earlier post Rob_GTZ but that is just that 'a post' it does not mean it is correct! Alot of things are mentioned in posts but are just crap! :roll:
And |1ttle_d3vil those pictures are an AE85 diff if my eyes serve me well. I can only see 8 bolts on the diff head and AE86 diff's have 10 bolts! Whoever sold you that diff my have ripped you off! 8O
There are diffs out of other vehicles that have the 10 bolt diffhead but not the disc brakes so if someone has one then it is probably one of these. If you put it next to an AE86 diff you will see that the shock mounts are different too.
Current rides;
1986 Levin GT
NZ_AE86
Postby Rob_GTZ » Tue Feb 15, 2005 9:32 pm
NZ_AE86 wrote:I have been thinking about this and unless I saw one I would not believe that any AE86 that had a factory fitted 4AGE came with drums.
Well you can believe whatever you want too, that's your choice. There's plenty of pictures & info about this floating around on the Net, In fact in Japan the GT coupes are more popular with the drifters as the drum brakes lock up alot easier than the discs
Rob_GTZ
Postby spencer » Tue Feb 15, 2005 9:42 pm
Id like to see this GT coupe, my carina wagon has drum t-series and a few others, maybe ask what mr revhead has on the epc about this gt coupe
ms63 crown
spencer
Postby Rob_GTZ » Tue Feb 15, 2005 10:08 pm
Or else you could try asking Reo from Garage Dori/Tama Autos, As he has actually owned at least a couple of GT Coupes
Rob_GTZ
85/86 diffs
Postby crispy'86 » Tue Feb 15, 2005 10:14 pm
And an important thing that hasn't been pointed out is that the ae85's had drum brakes as you all know but MORE IMPORTANTLY: AE85 DIFFS ARE 8 BOLT AE86 DIFFS ARE 10 BOLT. This is on the diff flanges where the head bolts to the housing. I'm surprised none of you pointed this out cause it's one of the more distinguishing features between the both of them
crispy'86
Postby RedMist » Wed Feb 16, 2005 7:04 am
I had an AE86 Trueno Coupe with drum rear. Most definately original, most definately AE86.
The answer is Helmholtz!
Toyota ST185 Celica Rally.
Toyota ST205 Celica Rally.
RedMist
Re: 85/86 diffs
Postby NZ_AE86 » Wed Feb 16, 2005 7:21 am
crispy'86 wrote:And an important thing that hasn't been pointed out is that the ae85's had drum brakes as you all know but MORE IMPORTANTLY: AE85 DIFFS ARE 8 BOLT AE86 DIFFS ARE 10 BOLT. This is on the diff flanges where the head bolts to the housing. I'm surprised none of you pointed this out cause it's one of the more distinguishing features between the both of them
Look up four posts!
Current rides;
1986 Levin GT
NZ_AE86
Re: 85/86 diffs
Postby l1ttle_d3vil » Wed Feb 16, 2005 7:48 am
ok well im not really tooworried about whether ae86s have drum brakes standard or what, i just wana know if this is an ae85 or 86 diff. im guessing its off an ae85.
strange thing is though that the AE86 LSD diff head i got off Yems has 8 bolt holes to bolt it to the diff housing!
Users browsing this forum: Bing [Bot] and 17 guests
