4AGE oil pumps?
4AGE oil pumps?
Postby matt dunn » Tue Feb 22, 2005 11:55 pm
Aparantly there are a few types of oil pumps that are available on the 4AGE's.
One has Aisan S1 on it and the other has Aisan S2.
Now the 20V that I have apart has Aisian 1 on it without the S.
Have they reverted back to using the old type pump, or is this another type??
Postby evil_si » Wed Feb 23, 2005 9:29 am
i have 2 4agze's sitting here from ae101's,
one has the aisan 1
and the other aisan 2,
but neither of them has an s before the number
is it just a casting number as to which product line it came from?
evil_si
Postby Mr Revhead » Wed Feb 23, 2005 4:19 pm
just done some looking...
part numbers for the ae101 pumps are the same for 20v and ae101 ze, they also share it with small port 16vs and late ae92 ze.
ae111 has a different one
the tvis ones are the same as each other. so 40mm crank and 42mm crank use same pumps in the ae82/early ae92tvis
also early 4agze in the ae92 uses the same as the tvis type pump.... so basicly it was an across the board change
so to answer your question it appears to be a casting number and has no bearing on the actual parts being different 8)
opil pump
Postby crispy'86 » Wed Feb 23, 2005 5:54 pm
I'll put the link up that will explain all this for u when i find it
crispy'86
Postby KinLoud » Wed Feb 23, 2005 9:34 pm
I have read that (can't find the reference so don't take this as gospel) :
-early 4age (bigport?) pumps are slightly lower volume and where sometimes prone to cracking at high rpm (i think)
-later pumps (small port? and AE101?) have bigger volume than the early ones to deal with the squirters and I think cracking problem solved. Identical to the TRD pumps available when the bigport was in production.
-Latest oil pumps - I have no clue about these...
Ken
Hamilton
021 408 863
Postby vvega » Wed Feb 23, 2005 9:38 pm
i have a blacktop oil pump on my kitchen table brand new and still in a box
ill take some piccys tomorrow
v
vvega
Postby NZ_AE86 » Wed Feb 23, 2005 10:28 pm
Don't quote me on this but I believe the only difference between Blacktop pumps and silvertop pumps is the casting on the front which allows the use of the Hydraulic tensioner?? :?:
Current rides;
1985 AE86 Race/Rally Car
1986 Levin GT
NZ_AE86
Postby Mr Revhead » Wed Feb 23, 2005 10:46 pm
that could be true, a different part number just tells me SOMETHING is different.... but not what
Postby FLAWLES » Thu Feb 24, 2005 5:18 pm
i have read u can use a 1ggte " i think " oil pump i think there a straight replacment
but az vvage will point out i have been wrong in the past
FLAWLES
Postby gdsup » Fri Feb 25, 2005 5:04 pm
has anyone had experience with aftermarket oil pumps, how much is a new unit worth?
gdsup
Postby craigt » Fri Feb 25, 2005 5:35 pm
I was told the smallport and GZE pumps had wider gears.
Wider gears means more volume, and as KinLoud suggested
they are also less prone to cracking at high rpm.
But I havent pulled any apart to find out!
If it doesn't fit, force it.
If it breaks it needed replacing anyway!
AE101 4AGZE
KP60 4AGTE project
craigt
