Fuel feed/return (4agze)
Postby 1598cc » Wed Feb 23, 2005 9:34 pm
just wondering which is the fuel feed and the fuel return for the fuel rail..
im chucking some extra injectors in and need to intersect the fuel feed .. just duno 100% which is in and which is out.. or does it matter
cheers!!
1598cc
Postby Lloyd » Wed Feb 23, 2005 9:37 pm
Fuel feed will be the line coming from the fuel filter :) And it will matter because the feed will be under the correct pressure and the return wont be
Postby 1598cc » Wed Feb 23, 2005 9:51 pm
sweet as.. cheers
you still runnin 14-15psi?? im going for 15psi with couple of gts-t extra injectors and a greddy rebic 2 i got lying around
1598cc
Postby Lloyd » Wed Feb 23, 2005 10:40 pm
Yeah its getting up there. Still on standard injectors only
