low_rider wrote:BRING BACK COMMUNAL SHOWERS!!!!!!!!!!!!!
RedMist wrote:Zac, thats warped.
The redtop smallport has bigger injectors than the bluetop. So the bluetop ECU needs to fire the injectors for longer in order to inject enough fuel for the bluetop to run. When installed in the redtop it still fires the injectors for the same period but now has the bigger redtop injectors. IE it will run very rich.
Don't know what happened in your case Zac, but I've a friend here in CHCH swapped a bluetop ECU into a redtop smallport engine, he was forced to change the injectors as it ran stupidly rich.
