RomanV wrote:But does it make up for the gas it uses? :p
/turbo envy mode 0
When the car was dead stock with gutted cat converter. 500kms to 54litres. 95% open road. After mods...a 'none to gentle' 465kms to 54 litres
/turbo envy mode 0
Al wrote:RomanV wrote:But does it make up for the gas it uses? :p
/turbo envy mode 0
RomanV wrote:when its not exactly hard (Or prohibitively expensive) to find a turbo model.
CozmoNz wrote:you let it completely run out of fuel?
bit sily in a efi car isnt it
Mmm, Boost wrote:CozmoNz wrote:you let it completely run out of fuel?
Why, its not a diesel
CozmoNz wrote:Mmm, Boost wrote:CozmoNz wrote:you let it completely run out of fuel?
Yeh, but if you run out of fuel.. your fuel line and rail presure drops right off.. injector opens.. half the amount of fuel that was *expected* comes out... and you run lean...
Lean = blows holes in pistons.
So if you timed it right, came on boost, ran out of fuel... maybe you could blow a hole in ya piston ^_^!
nah, seems silly to run outta petty oil though
Mmm, Boost wrote:CozmoNz wrote:Mmm, Boost wrote:CozmoNz wrote:you let it completely run out of fuel?
I was gonna have a big reply, but then I thought - why bother
