Do you no much about the 1jz??
Postby Gx71man » Tue Mar 08, 2005 10:30 pm
Rite. Im doin a 1jz swap into a cressida, i have had a look on the cressida fourms and found nothing regarding this matter.
It is a 1jz with a AUTO computer, loom, ect. I am putting in a manual box.
What should i do about the neutral/park start funtion (can only be started in n or park)
Any other things i gotta watch?? airbag fucn? Abs?
Also any body got any GOOD 1jz wirering diagrames???
NOTE: The cressida forums told me everything else tacho booster, crossmember, bla bla bla.
anybody put a 1j in anything else and come across these problems?
I Give My Mrs A 1/4 inch at a time, For those ten seconds or less Im Free...
Gx71man
Postby thaphatty » Tue Mar 08, 2005 10:33 pm
bridge inhibitor switch on loom. im not going to answer that question again.
have fun with yer 1jz :mrgreen: makes me somewhat jealous :D
thaphatty
Postby wde_bdy » Tue Mar 08, 2005 10:39 pm
If your car was originally auto there will be a neutral cut out switch, usually you can bypass this quite easily. Above the bellhousing area there should be two thickish black/white wires, simply bridge them. Will be in the same plug as the reverse lights etc most likely.
Callum
wde_bdy
Postby Gx71man » Tue Mar 08, 2005 10:41 pm
thaphatty wrote:bridge inhibitor switch on loom. im not going to answer that question again.
You no what might make you more jelous I got it 4 $1000 (loom computer all the shit to make it go) with a flywhell and pressure plate, low k's too. Oh and best of all, legit.
Gx71man
Re: Do you no much about the 1jz??
Postby Jason T » Tue Mar 08, 2005 10:54 pm
Fixing Toyota's since '87
Jason T
Users browsing this forum: No registered users and 41 guests
