Gearbox swaps on a Mk3 with digital dash - speedo issues
Postby Four_Seven » Fri Mar 11, 2005 7:11 pm
Don't know if this is in the right section but i've seen a mark III supra for sale with a gearbox conversion. Seems like a good deal but the digital dash is off because of the conversion.. - what ways do i have of fixing it? its got a 1G-GTE engine in it if that's any help.
Four_Seven
Postby Silent Knight » Fri Mar 11, 2005 8:42 pm
The manual conversion in itself would not put the speedo off except if the cable is not on properly. If you look at the bottom of the gearbox on the speedo drive make sure it's screwed on properly.
i've done this conversion myself in a ga70 with a 1g-gte and it doesn't affect the speedo at all. what kind of gearbox are you using or did you use?
Silent Knight
Postby Ae92typeX » Fri Mar 11, 2005 11:12 pm
Silent Knight wrote:The manual conversion in itself would not put the speedo off except if the cable is not on properly. If you look at the bottom of the gearbox on the speedo drive make sure it's screwed on properly.
You sure about that?
Its quite possible we are talking about my supra here. The speedo definatly did change with the manual conversion (w57) about 15-20% fast. It also jumps a little randomly, but im positive the conversion changed the speed. Cables are all sweet and in well. Drive gear is sweet.
Without quoting me Im sure hunt and afew others got a reducer gear set put in their speedos after auto-manual conversions.I was told the auto diff is geared different to the manual ones!?
Ae92typeX
Postby Silent Knight » Sat Mar 12, 2005 12:54 am
hrmmm that's very interesting then...
I didn't notice any sort of a difference at all once I finished with my conversion what so ever... :?
I used a W57 aswell. I wouldn't have thought it would matter at all. Anybody got the diff ratios from both auto and manual mk3s to compare?
Silent Knight
Postby Four_Seven » Sat Mar 12, 2005 1:09 am
AE92TypeX ygpm
So it's driven by a cable, not something electric? there's a kit at jaycar that'll tweak a digital signal but if the speedo reads off a cable it'd be useless...
Four_Seven
Postby Silent Knight » Sat Mar 12, 2005 1:15 am
I'm not completely sure with the digital dashes what is used to convert the data from the speedo cable to digital format but from the gearbox itself it's cable driven...
Silent Knight
Postby Akane » Sat Mar 12, 2005 2:35 am
Four_Seven wrote:AE92TypeX ygpm
OMG I LOVE YOU SO MUCH!
been trying to find a speedo correction kit for my 260kph EL dash kit for 4 FRIGGIN YEARS!
Postby deaf_rattle » Sat Mar 12, 2005 7:36 am
Ae92typeX wrote:Without quoting me Im sure hunt and afew others got a reducer gear set put in their speedos after auto-manual conversions.I was told the auto diff is geared different to the manual ones!?
Sounds to me that, thats your problem.
Not a biggy, but yeah you will need to grab the drive gear from the auto and put it into the new manual.
bobs your uncle.
Postby Ae92typeX » Sat Mar 12, 2005 7:54 am
bobs your uncle.
Problem with that is the drive gear was a different diameter from auto to manual- tried that when I did the conversion.
Ae92typeX
Postby deaf_rattle » Sat Mar 12, 2005 8:08 am
hmm
maybe a drive gear from a 7mgte auto then.
might be something to try
Postby Four_Seven » Sat Mar 12, 2005 9:51 am
HAHAHA no problem glad i could help :P
Four_Seven
Postby Ae92typeX » Sat Mar 12, 2005 10:11 am
deaf_rattle wrote:hmm
Good idea, will look into it. Im busy with my other project now, but if I have not sold when that is finished I will investigate further.
Cheer
Ae92typeX
