How to tell if gearbox oil is full empty etc??
Postby Banga69 » Mon Mar 21, 2005 3:15 pm
as the topic says. . .? no dip stick.
4AGZE
CURRENT:
1994 Mazda Lantis
EX:
SOLD: AE101 GTZ ====>http://toyspeed.blakjak.net/profiles/profile.php?id=89
Banga69
Postby CozmoNz » Mon Mar 21, 2005 3:24 pm
undo the filler bolt on the *front* of the gearbox (facing the front of the engine) if you will.
get a peice of straw / metal / paper etc
dip it in, the level should be slightly below the filler hole.
Rayne For President!
CozmoNz
Postby Banga69 » Mon Mar 21, 2005 4:53 pm
CozmoNz wrote:undo the filler bolt on the *front* of the gearbox (facing the front of the engine) if you will.
oh sweet, thats the bolt with the little cover on it aye where u can take off ? its damn hard to get to though
clint
CURRENT:
1994 Mazda Lantis
EX:
Banga69
Postby CozmoNz » Mon Mar 21, 2005 4:55 pm
clint
If you mean the stone cover, that is under the car, then yes.
not that hard, just need to wriggle around the wheels and stuff to get at those 2 by the wheel well.
why do you think its low / empty? has it been leaking?
CozmoNz
Postby Banga69 » Mon Mar 21, 2005 5:09 pm
nope not the stone cover under the car, i mean on top of the gearbox theres 2 bolts both are the same size but one has a circle cover over it that you can take off and a rubber hole under it.
CURRENT:
1994 Mazda Lantis
EX:
Banga69
Postby CozmoNz » Mon Mar 21, 2005 5:59 pm
Banga69 wrote:nope not the stone cover under the car, i mean on top of the gearbox theres 2 bolts both are the same size but one has a circle cover over it that you can take off and a rubber hole under it.
:O
i have no clue what your tlaking about.
pop the hood, and look down, youll see the gearbox
looking back at your knees will be a nut, thats the filler hole.
undo that and stick a peice of wire in to see the level.
CozmoNz
Postby ee904age » Mon Mar 21, 2005 6:21 pm
It will be a sump plug like bolt with a 24mm head, not the one with the cover though I dont know what thats for, mine has that aswell.
90 SW20 Turbo - Project
90 SW20 N/A - Sold
ee904age
Postby Mr Revhead » Mon Mar 21, 2005 9:14 pm
yeah on the front of the gearbox, about half way up. 24mm large bung. correct level is level with the bottom of the hole. a little drippling out is fine.
it may or may not be accsessible from the top in a gtz.
should be able to get it off with out removing the undertray
Postby Banga69 » Tue Mar 22, 2005 12:28 pm
oh cheers guys. must have been looking to far up.
ta
clint
CURRENT:
1994 Mazda Lantis
EX:
Banga69
Postby kingcorolla » Tue Mar 22, 2005 7:32 pm
If you whip the filler bung out, and no oil drips out, there is not enough.
the correct amount, is how much you can pour in untill it dribbles out the filler hole.
Thats the way they are made.
1983 Carina AA63 4age
kingcorolla
4agze box
Postby crispy'86 » Tue Mar 22, 2005 11:32 pm
Yeah halfway up the box casing there's a 24mm bolt as stated, maybe if someone has a pic to give him an idea of what he's looking for ? :wink:
crispy'86
Postby Banga69 » Wed Mar 23, 2005 12:47 pm
have not checkd yet, as its been shit waether down in welly
CURRENT:
1994 Mazda Lantis
EX:
Banga69
Postby CozmoNz » Wed Mar 23, 2005 2:54 pm
my trueno isnt outside :(, when i get a spare moment with the car, and have a camera near by, ill take a pic.
CozmoNz
Postby Banga69 » Wed Mar 23, 2005 3:20 pm
CozmoNz wrote:my trueno isnt outside :(, when i get a spare moment with the car, and have a camera near by, ill take a pic.
that be great :D
CURRENT:
1994 Mazda Lantis
EX:
Banga69
Users browsing this forum: Google [Bot] and 27 guests
