crshbndct wrote:also might have something to do with the fact that ona subaru one set of exhaust runners is about 2x the length of the other set.
sopachrga wrote:vvega, you have missed the point of what is being asked.
It is plainly obvious what you have just stated, but the question was aimed at two motors both 2L in capacity, with different stoke and bore measurements.
And changing the capacity of the engine would make a very signifigant change in sound and volume not, a difference that you refered to as "most probably barly audible "
RomanV wrote:Aaah! Ive found a way to explain myself more clearly. (perhaps)
Imagine if we plotted a graph with exhaust pressure on the vertical axis, and the time span of one exhaust stroke of the engine along the horizontal.
The two different engines would have (roughly) the same amount of area under the graph (amount of gas being pushed out) but the shape of the curve would be different.
eg. The big bore engine would have a peakier curve than the small bore.
The small bore engine would have a lower peak, but the pressure would be more spread (Less pressure variation) across the range.
Hence the 'pulse' of exhaust gas from the big bore, rather than a more constant flow.
Make sense?
vvega wrote:sopachrga wrote:vvega, you have missed the point of what is being asked.
changing 60cc as the result of a overbore will not change sound significantly
real world experiance tells me this
sorry i dissagree with you but you are painfuly and obviously wrong on both accounts accept iy and get on with it...
the answer is yes it will ....
any change to engine dynamics ... bore vrs storke ..engine layout.. cams...tyoe of induction will all change you exhaust note
again symple physic's
your resonate value(the sound your engine makes) is dependant on the rest of the pulse and flow dynamics for it very makeup ....
like i said simple stuff
crshbndct wrote:also might have something to do with the fact that on a subaru one set of exhaust runners is about 2x the length of the other set.
TygerTung wrote:See you will notice that a lot of subaru rally cars have the equal length headers and just have a smooth 4cyl sound.
sopachrga wrote:At no stage did I say that it would not change the sound, I said that it would not change the speed or pressure of the air coming out of the cylinder. due to the fact that a piston with a larger bore will travel slower than a piston with a smaller bore at the same Revs.....
Once you can get this in to your head and stop making up imaginary arguments, maybe you could learn to read, and spell.
Before you try to rubbish any of my statements in the future I would prefer you to read what I have said and only try to prove me wrong on statements I have actually made.
Users browsing this forum: No registered users and 48 guests
