trdfxgt wrote:with out knowing how much you know about timing and things could it be 180 degrees out ?
Dr-X wrote:You have spark, you have fuel. Assuming all you've done is change the cam, there's only 2 possibilities - either your cam timing is out, or your dizzy is out 180deg. Triple check it.
vvega wrote:when you get sick of tring to sort it tow it over and ill sort it for you
hahha
v
Users browsing this forum: No registered users and 39 guests
