Ive recently purchased a 4agze motivated ee101 corolla...
problem is the s/c is on the way out and after lookin around ive discovered theyre as rare as hens teeth and no-one in Auckland rebuilds them.
After 2-3 weeks of research im thinkin the best bet is to replace the whole engine with a silver/blacktop...considering reliability, saleability and the knowledge that i know more about what the new engine has done (along with warranty, etc)...
Problem is im not entirely sure what 4agze ive got with respect to afm/map...
I was led to believe the engine is out of an ae92 and from what ive found these came out with both map and afm...so far the only distinguishing info ive got is that the earlier afm engines used a distributor as opposed to the latter map engines which used twin coil?...this correct?
So potentialy it still could come down to a change from map to afm or vice versa dependn on what engine i replace it with so...
how big a job to change from 1 to the other?...any comments/suggestions would be greatly appreciated...
Bearing in mind itll be done professionaly, are there any shops in the Auckland area which have experience with this type of conversion?
Ive priced up the parts for the silvertop conversion and found it to be within budget but kinda comes down to weather its gona need rewiring etc... so any help/info would be great
thanks
C
