belt problems, help
belt problems, help
Postby dragg_racer666 » Wed Apr 06, 2005 10:43 am
ok i got up this morning and started my car. it was warming upand i came back inside. but when i went back out to leave i looked at the front of my car and i seen that the s/c , water punp belt had fulen off and also was the altinator p/s belt had fullen off and were just lying on the ground. now what could of corsed these belts to fall off there pullys. they were on there properly. and also the altinator belt was all frayed on tha r/h side. what has happened to my engine
dragg_racer666
Postby Fandango » Wed Apr 06, 2005 11:45 am
well your altinator pully was probably streched n worn, and when it came off took the other one with it.
just replace them, check your pullys tho.. the v in one of them could be stuffed.
Fandango
Postby Banga69 » Wed Apr 06, 2005 12:07 pm
yea check all your pulleys as they my not be spining around and causing the belts to stretch and rip off. also check to see if your water pump is spinning aswell, as it could rust and stop spinning.
hope that helps.
CURRENT:
1994 Mazda Lantis
EX:
SOLD: AE101 GTZ ====>http://toyspeed.blakjak.net/profiles/profile.php?id=89
Banga69
Postby dragg_racer666 » Wed Apr 06, 2005 12:33 pm
all my pullys are spinning fine. maby the belts are just $&#$%. i'm thinking it may be the altinator, i'm going to put a new one on today and i'll see how it gose. i'll post back after that
dragg_racer666
Postby Banga69 » Wed Apr 06, 2005 2:07 pm
dragg_racer666 wrote:all my pullys are spinning fine. maby the belts are just $&#$%. i'm thinking it may be the altinator, i'm going to put a new one on today and i'll see how it gose. i'll post back after that
how much boost you running? what size is your crank?
CURRENT:
1994 Mazda Lantis
EX:
Banga69
Postby dragg_racer666 » Wed Apr 06, 2005 3:37 pm
everything is just standaed on it at the moment. just running 8 pound. i'm actely wondering if everything is because my mate has the exact same car and his is standard as well but mine wiped it. so maby his was getting worn. i duno
also i'm still having the prob with the belts
dragg_racer666
Postby fuel » Wed Apr 06, 2005 6:55 pm
have you checked the belts condition? If the multi ribbed belts have any cracks or chunks taken out of them, replace it. It was probably a sign that your belts were too worn or not tensioned properly anyway.
fuel
Postby evil_si » Wed Apr 06, 2005 9:17 pm
while your at it, you should learn how to spell :roll:
belts do wear, and break, and if the pulleys are aligned incorrectly it will make the belts 'walk' off
evil_si
Postby dragg_racer666 » Wed Apr 06, 2005 11:10 pm
dude no need to attack me on my spelling. i dont care if i can or not.
yea i'm going to get new belts tomorrow. and if i have any more trouble i'm just going to put in it the guarage for them to play with. i think the supercharge / waterpump belt was streched and worn.
dragg_racer666
Postby Banga69 » Thu Apr 07, 2005 11:33 am
dragg_racer666 wrote:dude no need to attack me on my spelling. i dont care if i can or not.
as other have said could be worn belts as in chunks taken out of the "V" groves, but you havnt told us if there is or not.
let us know what happend when you get new belts
clint
CURRENT:
1994 Mazda Lantis
EX:
Banga69
