Can I simply put the 16V cam gears on the 20V head?
Are the valve going to hit pistons in normal operation? (Assuming the cambelt is in the right place
The breather from the rocker cover does feed into all the throttles does it? (Need a feed for the MAP sensor)
There will be a few more things but I cant think of them right now.\
Ta.
