1998 wrote:And don't think you can get away with gutting it a putting it back on. They actually take a reading as to your emmisions.
sergei wrote:NOPE they dont! EFI doen't mean it has to have OX sensor, and check many NZ new cars don't have, I used to own a camry it didn't, my mate has Corolla GTi - it doesnt, and if you specifically look under bonnet most of early 90 late 80, NZ new cars, don't have Oxygen Sensor or Cat, because theywere designed for shitty NZ fuel at that time (tetra-ethyl-lead)
TRDWGN wrote:best solution is to get a small resonator fitted up with flanges that match the cat so if and when (I know it is to become compulsary but they have been promising this since about 2002!!) you can easily replace it.
The cat is probably the single biggest restriction in the entire exhaust system although it doesn't alter the sound as much as people think, yes removing it does increase the noise but not by much, removing the resonator down line of the cat will make a huge difference in noise, but it is straight through so no real advantage in removing it...
If you are interested in buying a whole exhaust i will be selling mine in a few weeks, it is a 63mm mandrel bent Fujitsubo system, the cat has been replaced by a little resonator, and the rear muffler has been replaced by a N1 style cannon style straight though muffler. It is loud enough to be heard and slightly too loud for me in my old age although it is well and truly legal and have never had any police or wof issues. It is definitely not tinny, raspy or other and yes it pumps out flames on upchanges quite nicely!!!!
sergei wrote:oh, also some of the carbies have OX sensors and CAT, so ox sensor/cat doesnt mean its has to be on EFI engine
HRT wrote:sergei wrote:oh, also some of the carbies have OX sensors and CAT, so ox sensor/cat doesnt mean its has to be on EFI engine
Ummm.... why exactly would a carby engine have an oxy sensor? So the computer which it doesn't have can say to itself that its running lean and cant do anything about it anyway?
