Fuel injection on rwd DX, etc
Postby gepsk8 » Sun Apr 10, 2005 6:59 pm
Hey,
has anyone done converted a carby to a injected?
what did you about fuel lines? was thinking of upgrading the line's
fuel pump?
any hints?
gepsk8
Postby wde_bdy » Sun Apr 10, 2005 7:32 pm
Grab a line off another TE or KE 70/71 for your return, easier than trying to bend one to fit and will clamp straight in beside the original. My KE70 has the pump mounted to the front edge of the tank behind the diff, but it was a wagon. Surge was sorted by welding a 4 inch diameter pipe around 3 inches deep to the bottom of the tank under the drain bung (tank was drilled out), holds around 0.5 L and pump feeds off the side of this. May be tricky on a sedan/liftback due to tank hanging lower. Return line was fed into original pickup. You can get cheap plastic EFI fuel filters too which make it easier to match up lines etc.
Callum
wde_bdy
Postby Me_19588 » Sun Apr 10, 2005 8:27 pm
hay man i have a spare fuel line off a sedan if u want one, just chucked another one out today aswell
Me_19588
Postby gepsk8 » Mon Apr 11, 2005 10:02 pm
yea, i got told upgrading is a must do! so i don't need the line, cheers anyway
gepsk8
Postby wde_bdy » Mon Apr 11, 2005 10:05 pm
gepsk8 wrote:yea, i got told upgrading is a must do! so i don't need the line, cheers anyway
Bigger fuel line will not be necessary unless you are chasing mega horsepower. What engine are you putting in?
Callum
wde_bdy
Postby gepsk8 » Mon Apr 11, 2005 10:09 pm
2t-geu then something not n/a (you will have to wait & see) later on so i was thinking do them right the first time.
gepsk8
Postby matt dunn » Tue Apr 12, 2005 12:39 am
Callum
A carbutetted car only flows through the fuel line what the cars uses,
say maybe .25 litres a minute?
A fuel injected car flows full plump flow through the lines at all times which can be up to 3 or 4 lires a minute.
Also a carb'd car probably will not have a return line where as a EFI car does need one.
Matt
Postby wde_bdy » Tue Apr 12, 2005 9:38 am
Yes as I noted above you do need a return line, I just used another standard feed for the return. Carb may use less gas as it is not recirculating fuel, but it is also sucking the fuel rather than pushing at high pressure. I compared my factory 3T-GTE fuel line to the KE70 one and there was minimal difference, given people can step up the horsepower of a standard car quite significantly without replacing the lines then unless you are chasing big horsepower an upgrade is not necessary. If you are chasing massive power then yes an upgrade is worthwhile.
Callum
wde_bdy
Postby Jebus » Tue Apr 12, 2005 12:35 pm
Also remember if youre using your standard lines, replace all of the rubber sections with EFI rated rubber.
Jebus
