Illumination of instrument cluster
Postby BZ Touring » Thu Apr 14, 2005 2:31 pm
OK, so the car is an 1996 AE101 Corolla wagon (BZ Touring model).
I'm interested in changing the colour of the illumination behind the instrument cluster (currently a delightful orange).
Couple of questions:
1. How is the cluster illuminated? (i.e. lamps or LEDs, removable/replacable or built in?)
2. Is it possible to remove what ever illumination is currently behind the instrument cluster and replace it with an after market part?
3. What is the procedure for removing the illumination?
4. What aftermarket part (if any) should I be keeping an eye out for?
Any help (or web sites) would be appreciated.
Cheers.
BZ Touring
Re: Illumination of instrument cluster
Postby pervert » Thu Apr 14, 2005 2:36 pm
BZ Touring wrote:1. How is the cluster illuminated? (i.e. lamps or LEDs, removable/replacable or built in?)
(1) LED's or lamps, could go either way (not sure about that particular model), should be removable.
(2) You can either buy a whole new set of LED's/bulbs, or get rubber coloured covers, or the cheap way, just colour the existing bulbs in with a vivid, actually works a treat.
(3) Unscrew the dash around the cluster, and cluster screws, and pull it out, watch the speedo cable as it is sometimes hard to get back in.
(4) None, DIY is better.
pervert
Postby Santa'sBoostinSleigh » Thu Apr 14, 2005 2:55 pm
4. Depends if you wanna go fully custom or just change the light colour.
just doing the lights is simple and can look good :)
Santa's Mega Sale
Santa's TardMe Listings
GTFX: viewtopic.php?t=67655
Users browsing this forum: Bing [Bot], Google [Bot] and 10 guests
