urgent - misfiring? sounds liek a wrx st205
Postby TRDmod » Sun Apr 17, 2005 11:14 pm
well,y 205 sounds like a darn wrx..u know the sound where you can hear the individual ripple of osund
my car usually has a synchrosous hummmm, but recently int he last week or so, when i start it ...first of all, it has trouble starting, like it tries but then halfway the starting it just stops, i try a few times and it works...then when it does, sometimes it sounds like a wrx with a loud exhaust, the engine kinda shudders, i cant accelerate properly or boost properly (i dont try cos i dont wanna F@ck it) but yeah, then after driving around for a lil bit, whent he engine becomes warm, it becomes normal as if nothing is happening........
i took it to toyota once and they listen ed to it and he said it was missing.....and then right efore i left toyota it became normal hence the pattern of when the engine warms up...
now? anyone tell me what this could be, i mean the toyota mechanic obviously knows but wanna be sure
Have you got the hots? for what's in the box with the dots? ..... 0800 30 40 50
Domino's Pizza.....
TRDmod
Postby sergei » Sun Apr 17, 2005 11:42 pm
check spark plugs, leads, and dissy cap, check if water is in spark plugs area, or in dissy, and if everything is ok, check for ECU error codes...
ok
Postby TRDmod » Sun Apr 17, 2005 11:47 pm
what the hell is dissy?
Domino's Pizza.....
TRDmod
Postby AJz » Sun Apr 17, 2005 11:48 pm
distributor, what your spark plug leads plug into dude.
I had vtax :(
AJz
hah
Postby TRDmod » Sun Apr 17, 2005 11:52 pm
ok, shiz
i just figured that out now, dissy, iw as like what the heck is that sweet f@cking jesus, all thes jargon
ok, i got it
Domino's Pizza.....
TRDmod
ok
Postby TRDmod » Sun Apr 17, 2005 11:53 pm
why would it suddenly be ok after 5 mins of driving?
i mean if theres someting royally fuggered bout it
then it shouldnt come right? ist hat right?.
or wrong?
im guessing here
thanks
Domino's Pizza.....
TRDmod
Postby Twolitre » Mon Apr 18, 2005 12:05 am
Check your leads, they should have the year of manufacture stamped on them, if they are the same year as the manufactures date of your car then change them along with the distributor cap and rotor, may as well do your plugs at the same time, and as the other guys have said check your ecu error codes too and if you don't know how to do that then search the database as it's been covered numerous times.
Twolitre
ok
Postby TRDmod » Mon Apr 18, 2005 12:09 am
ecu error codes, how do i get the display, not like i hav a computer from toyota lying around, i just plug and play
Domino's Pizza.....
TRDmod
Re: ok
Postby Twolitre » Mon Apr 18, 2005 12:28 am
TRDmod wrote:ecu error codes, how do i get the display, not like i hav a computer from toyota lying around, i just plug and play
I don't understand what you are trying to say, are you implying that you have an aftermarket computer? or are you too lazy to search the forum on the correct way of extracting the ecu error codes from your stock ecu? because if so you don't need anything other than a paper clip.
Twolitre
Postby matt dunn » Mon Apr 18, 2005 12:37 am
Possibly a temp sensor, but toyota temp sensors are normally quite reliable. ( as compared to other brands)
Postby Dr-X » Mon Apr 18, 2005 9:24 am
It definatley sounds like it's running on 3, so temp sensor is unlikely. TRDmod, it sounds like you dont have much in the way of knowledge with cars, perhaps you should take it to your mechanic. It's almost definately going to be an ignition problem, they should be able to isolate it pretty quickly.
If you really want to do it yourself, first try some different leads. That seems like the most obvious answer - if that doesnt help, keep working backwards through your ignition system.
Dr-X
Postby CozmoNz » Mon Apr 18, 2005 3:31 pm
hit the *anti-lag* switch again.
what did i tell you about pressing the red button?
Rayne For President!
CozmoNz
Postby low_rider » Mon Apr 18, 2005 5:24 pm
i know this sounds stupid but just make sure all your plugs are in properly and that your leads are all plugged in properly aswell,make clean out your dizzy cap if u know what your doing. :)
rulk
low_rider wrote:BRING BACK COMMUNAL SHOWERS!!!!!!!!!!!!!
http://toyspeed.blakjak.net/profiles/profile.php?id=336
low_rider
Users browsing this forum: Bing [Bot], Google [Bot] and 18 guests
