It could be that the only fuel the motor is getting is through the cold start injector (which is mounted on the plenum chamber).
If there isnt 12v then check the 'inj' fuse mounted on the airbox.
Also, there should be a whole lot of solenoids mounted on the ecu end of the engine loom.
l1ttle_d3vil wrote:that yellow plug is not for the ignitor - it is for the air/con or something like you said.
i found the right plug for the ignitor/coil on another loom and have traced the four wires all the way back - two go to the ECU, one to a yellow plug with a fuse on it (duno what its for), and the other one goes to the yellow plug in the bottom of this pic.
ee904age wrote:If your loom is complete it WILL have an INJ fuse, it will be 10A (I think) inside a yellow plug with a black cap on it. It uses an adaptor type thing to convert from a normal two pin plug to a fuse holder.
Ill check what the plug looks like without the adaptor as it may have been taken out at some stage, in which case it could be one of the 'plugs to nowhere' in the pics from your 1st thead.
Shay
HRT wrote:Are there any other marks on the cam pulleys? The gears on the silvertop I pulled to bits had 2 marks on the pulleys, one of each lined up as you've put and the other 2 lined up with themselves where the pulleys are closest to each other, much like Subaru timing marks do.
ChaosAD wrote:Do you have the right ecu?
ChaosAD wrote:
Matt dunn> will the import 4ages spark if the ecu isnt getting power?
ee904age wrote:I would get it warmed up an keep it running for a while before worrying too much about idle etc.
