shouldnt i have more power??
Postby Silvergun » Wed Apr 20, 2005 7:40 pm
I recently got my toyota tuned on a dyno, but im a bit confused with the results.
Car info:
ae92
4age red top
2 1/4" exhuast 3" muffler
pod filter
possibly aftermarket cams
Before tune = 76KW 101.9HP
After tune = 79.7kw 106.9HP
So i got some gain with new plugs, adjuted timing, cleaned dizzy cap and adjusted throttle position sensor and that seems normal.
my problem is that i thought a red top put out 100KW standard and mine could only get to 79.7KW. Ive thought there may be a couple of reasons why:
1/ Dyno is wrong??
2/ Engine is not redtop - colour of engine lettering is as follows:TWIN CAM 16VALCE (in red); TOYOTA 1600 (in black)
3/ Engine was getting massive heatsoak from position of pod filter which has now been shifted but was directly behind battery (ie about 40cm from throttle body near where panel filter airbox was)??
4/ There is simething seriously wrong with engine (maybe compression???). has nearly done 200ks.
anyone have any thoughts as to other reasons why i aint got the sort of power that should be expected from the engine??
AE92 4age Redtop
Silvergun
Postby Adamal » Wed Apr 20, 2005 7:52 pm
Combination of Toyota's exagerated power figures and wear and tear.
Engines do not stay the same power figures over time :)
Postby Al » Wed Apr 20, 2005 7:52 pm
Sounds about right.
100kw is at the engine, your dyno will read power at the wheels.
Al
Postby 1598cc » Wed Apr 20, 2005 9:19 pm
that aint a bad gain just from these:
1598cc
Postby CAMB01 » Thu Apr 21, 2005 9:36 pm
if the engine lettering colour is red and black then its a T-VIS 4AGE, which has 88kw from factory.
1993 Mitsubishi EVO 1 Racecar
1989 AE91 FX-ZS (Previous)
Custom Works Automotive
http://www.HCCC.org.nz
CAMB01
Postby GT4 20 » Thu Apr 21, 2005 10:19 pm
Al wrote:Sounds about right.
The words..
Nail
On
Head
The
Hit
The
come readily to mind :wink:
Gary
1999 Subaru Legacy B4 RSK TT
GT4 20
Postby Twolitre » Thu Apr 21, 2005 11:21 pm
80kw @ wheels is a good result from a near stock 15 year old Toyota engine rated 100kW at the engine like the others have said but dyno's vary so much, at the end of the day it's only a number and what it feels like on the road should be your main priority, ie. does it feel responsive? any flat spots? revs cleanly through to redline etc
Twolitre
Postby Silvergun » Fri Apr 22, 2005 2:09 pm
CAMB01 wrote:if the engine lettering colour is red and black then its a T-VIS 4AGE, which has 88kw from factory.
it is my understanding after reading many other threads that a 1991 AE92 corolla cannot be the TVIS 4age. '89 was the last year TVIS was made. All red tops after that were the non-TVIS redtop smallport hence factory rating 100kw.
im guessing that a dyno reading ''at the wheels'' is always less than the reading at the engine then.
its not that responsive below 3500rpms but thats consistent with it being a smallport 4age. Between 4000 and 6000 its at its best then seems to taper off after that. find its best to change just over 6000.
AE92 4age Redtop
Silvergun
Postby Distrb » Fri Apr 22, 2005 2:12 pm
Silvergun wrote:im guessing that a dyno reading ''at the wheels'' is always less than the reading at the engine then.
This is because you lose power through the drivetrain. 4wd vehicles tend to lose the most in this situation
heres a decent read about it if you have the time
http://www.superstang.com/horsepower.htm
Distrb
Regular Poster
Postby mr pad » Fri Apr 22, 2005 3:21 pm
Your right a dyno reading at the wheels is less.
Not all smallports are unresponsive below 3500. Ive found them to be better down low than big ports and my old redtop would happily rev to 7 with no noticible power drop off, more if ya let it...
Red and black is a small port.
Yep you got the 100kw motor and I would be really happy with that result.
Thats really good for such an old motor.
mr pad
Postby Gavin » Tue Apr 26, 2005 3:34 am
http://www.club4ag.com/faq%20and%20tech ... ations.htm
Looks like you have a smallport low-comp.
ADMIN EDIT: stupidly large image removed
20v Powered AE92 wagon (20v turbo project)
78 280z Black Pearl Edition AutoX'er
Gavin
Postby Drifter4ag » Tue Apr 26, 2005 11:28 am
no such thing as small port low comp ...
if your intake manifold says TVIS then you have an 88kw motor..
either way 79kw is consistant with an 88kw motor on the dyno with minimal mods
Garage |-" '|
Current Rides
AE86 Notchy (Finally through compliance after 5 years)
Vitz RS :D
Previous,
1x SXE10 Altezza, 2xAE111 Caribs, 3xKP60, 2xke35 SR Coupes, 2xAE85s, 2xAE86 Road Car, 1xAE86 Drift Car 182kw@wheels, 1xJZZ30 Drift Car 360ps
Panspeed Special 450ps Drift Car
JZX91 MARK II CHASER
JZX81 MARK II CHASER..... so many more that i forgot....
Drifter4ag
Postby matt dunn » Tue Apr 26, 2005 10:39 pm
The year that your car was registered is not nessarily the year it was made.
Matt
Postby AE85coupe » Tue Apr 26, 2005 10:48 pm
a mate of mine had a silver-top 20v that only put out 80kw at the wheels... so yeah
smallports rock
AE85 Trueno *For sale*
Details of car here
AE85coupe
Postby H8HNDA » Wed Apr 27, 2005 12:17 pm
i got my ae82 dynoed the other day on a hub dyno and it came out at 97hp sae with my max power being at 7 grand.
its got standard internals with a pod filter and an exaust.
H8HNDA
