by widebodyhachi » Fri May 06, 2005 3:57 pm
What machining has to be done they share the same wheel bearing its just the physical hub design that differs, dosnt it?
I was under the impressions that its all a bolt on since they share the same code for carrier but this is toyota where talking about after all
