Bazda wrote:I would do one with a breather.
But not buy these cheap catch cans which are hollow inside.
Get a proper one made with baffles/plates inside and a drain back to the sump if you want to do a proper job.
JT wrote:Bazda wrote:I would do one with a breather.
Would you want the condensated fumes to go back into the sump though? Even if it's not a problem I wouldn't bother wasting time putting a tap into the sump for that. I do sugest having one with a breather though.
Bazda wrote:Oil will drain back down to the sump, fumes will go out the breather. Thats how it works.
Pick up any perforamnce car tuning book and this is one of the first steps to do.
BZG|Bling wrote:whats wrong with just putting a coke bottle in the engine bay with a hose leading into it from the cam cover?
serious question :)
oh btw i DO NOT have this setup :P but may look at it, rangi styles
JT wrote:Bazda wrote:Oil will drain back down to the sump, fumes will go out the breather. Thats how it works.
The oil that is draining away was previously being combusted so I don't see any advantage in returning it to the sump.
RedMist wrote:Thought Ausi touring cars were dry sumped? Hence the 5l dry sump tank.
I think you'll find those "returns", scavenge lines, actually taking oil from the sump.
Bazda wrote:On my dads escort he has a 9L tank for the dry sump system as thats only for a 2L car. He has to run a 2L oil catch can system that drains back to the sump, if it wasnt that big it would over flow.
serious question![]()
oh btw i DO NOT have this setupbut may look at it, rangi styles
BZG|Bling wrote:only wanting to 'fiddle' and see the results of having such a 'catch can' I don't lift the bonnet much, so doesnt warrant my spending $100+ on such a bling device
