Theoretical shock absorber question
Postby ATAl » Tue May 10, 2005 8:53 pm
I was thinking on my way home (it's a long way) that it should be possible to create a firmer shock absorber if you pulled one apart (non-sealed type), drained out all the old oil and replaced it with heavy grade oil.
Any reason this couldn't work?
I'm not actually doing this, just wondering if it's feasible.
ATAl
Postby Dangerous_Driver » Tue May 10, 2005 9:52 pm
yes also brake fluid instead of oil works! only really want to do it if ur shocks are shot though!
My sister can do a better standy!!!
http://toyspeed.blakjak.net/profiles/pr ... hp?id=1365
Dangerous_Driver
Postby Mr Revhead » Tue May 10, 2005 9:55 pm
yes its totally doable, in fact bikes do it.
iv seen it done on a race car, a lot cheaper than adjustable shocks.
theres proper shock oil you can use, i suspect its closer to hydrolic oil rather than engine oil though
Postby thaphatty » Tue May 10, 2005 10:07 pm
yip works very well, can even do it in some r/c cars
thaphatty
Postby ATAl » Tue May 10, 2005 10:58 pm
Hmm very interesting, thanks for the info :D
ATAl
Postby TRD Man » Wed May 11, 2005 10:05 am
Yes. In the days before you could buy inserts we used to do this to our rally suspension.
TRD Man
Postby RedMist » Wed May 11, 2005 8:11 pm
Trans Fluid, hydrolic fluid and oil all dont have the same anti airation qualities as proper shock oil. It means that in constant use, such as a bumpy road the fluid airates and the shock becomes much less effective. You really want to use a shock oil in a shock for that purpose, they come in varying grades with something to suit.
Also if the fluid is not viscous enough you can hydrolic the shock and either bend the shaft or explode the shock.
The answer is Helmholtz!
Toyota ST185 Celica Rally.
Toyota ST205 Celica Rally.
RedMist
