SLOTTED BRAKES.....12 or 6 slots
Postby Stealer Of Souls » Tue Mar 29, 2005 3:53 pm
Something was said earlier about the pads binding to the rotor... this is probably what's happening. The article link I posted earlier eludes to this. It says something about cheap pads basically "coating" the rotor with a high friction layer. The pad then grabs this layer and just sticks. So no time for weight transfer and grip becomes exceeded...
This would mean that only an insanely grippy tyre could stop that from happening...
'86 AE85.5 Levin
Stealer Of Souls
Postby suberimakuri » Tue Mar 29, 2005 4:25 pm
Your suggestion and experience at the track is good information Simon. I understand that situation.
I don't think it's a 'grabby' issue.... as i've had some crappy ($15) pads that don't grab. But the wheel still locks up.
I've been hesitant in using "wheel/tire locks up", as it can be read that the tire is failing to keep grip.
So, I think i'm going to be stubborn and lean to this statement: "cheaper pads will bind quicker for whatever reason".
suberimakuri
Postby BZ-G » Mon May 16, 2005 10:06 pm
I don’t know how slotted rotors really work…. But all I know is that drilled rotors tend to crack a lot easier under heavy braking… that’s why I have used slotted instead of drilled…
Cost of Brembo 6 slot front rotors on AE111 BZ-G is only $380NZD… So it’s cheap compared to DBA and an upgrade price from standard rotors… Part # DR708V…
If you do go on the track… what really stops a car is not only rotors and brake pads… you got to incorporate tires, suspension, brake fluid, brake line, master brake cylinder stopper and disable the ASB system… after all this you can out brake any race car with an AE111…. Like me… :lol:
Phil
AE111 Trueno BZ-G
BZ-G
Postby GT4 20 » Mon May 16, 2005 11:22 pm
BZ-G wrote:I don’t know how slotted rotors really work….
Not quite sure what you're saying, but the slots are designed to allow gasses to escape. As a result of heat, pads can give off a gas which can build up between teh pad and rotor. This gas effectively reduces friction - sometimes to the extent where brake fade is experienced. The slots simply allow the gas to escape and at the same time, help deglaze the pad.
Gary
1999 Subaru Legacy B4 RSK TT
GT4 20
Postby TygerTung » Mon May 16, 2005 11:44 pm
Putting bigger brakes on your car won't make it stop quicker, but you you'll be able to stop quickly more times.
My factory 1975 corolla brakes can lock the wheels at too kmh no worries.
TygerTung
Postby matt dunn » Tue May 17, 2005 12:42 am
TygerTung wrote:Putting bigger brakes on your car won't make it stop quicker, but you you'll be able to stop quickly more times.
So two cars with 1000kg weight,
One has 135mm discs and one has 325mm discs and four pot calipers,
You say that if they both are driving at 150k and then stop as quik as they can that they will stop in the same place?
Postby Al » Tue May 17, 2005 12:53 am
Providing the smaller of the two braking systems can infact lock the wheels and the cars are identical, even down to tyres. Yes.
Doesnt matter how big the brakes are for one stop, you only have two friction points. The pad/rotor and the tyre/road. If you can lock the pad/rotor then the only way to stop quicker is by increasing the friction with the road.
Al
Postby matt dunn » Tue May 17, 2005 1:28 am
You have obviously never been in a car with truly big brakes then.
Postby Perky » Tue May 17, 2005 6:39 pm
This must be correct, but doesn't it assume that the wheels of the two cars are locking at the same time? Until the wheel locks the larger brakes have more friction and I'd expect them to scrub off speed more quickly and lock earlier. Since, ideally, most braking won't involve wheel locking, this should make a difference but maybe in emergency stops the wheels lock so quickly that it is irrelevant.
Perky
Postby JT » Tue May 17, 2005 7:14 pm
matt dunn wrote:You have obviously never been in a car with truly big brakes then.
Bigger brakes fight heat better after repeated stops.
What this means is, in a single 100-0 stop you will only slow well as brakes can fight the heat and the tires can keep traction. The brakes don't have that much heat to fight in one single stop and you could lock up most road car tires with the brakes from a good stomp on the pedal.
All a brake upgrade is going to do is make the brakes more resistant to fade, unless you get better tires too.
The car you have been in with truly big brakes probably has racing slicks on too? This means the better brakes can stop the car quicker because the tires will not lock up so easily
JT
Postby Al » Tue May 17, 2005 7:28 pm
I bet the cars you went in with these truly big brakes also had nice sticky race rubber as well :wink:
Al
Postby TygerTung » Tue May 17, 2005 9:03 pm
Yeh mate, as long as the 135mm brakes don't overheat during that stop,(which they shouldn't) You'll be able to stop the same time.
But if you want to do it more times, you'll need the bigger brakes, as each time you do it, the brakes will get hotter and hotter.
TygerTung
Postby lill fuk » Wed May 18, 2005 9:11 pm
ok so on the subject of brakes wot can i do to mine standard sw20 mr2 if i wonted to do the targa tour thingy nxt year do i worry bout rotors as its not a competitive event or do i jst get decent pads?
lill fuk
