Picture of 4k engine bay
Postby 1goodidea » Mon May 16, 2005 11:41 am
Hey, just asking if some people could post pictures of there engine bay with a 4k in it?
Just need to make sure my vacum lines a correctly hooked up.
As at the moment the motor is running sweet, idling well but is abit hesitant (sp) at low revs.
I have the hose comming out of the carb and connecting to the intake manifold and no hose going to the Ignition advance unit on the side of the dizzy.
Thanks
James
1goodidea
Postby ke_25 » Mon May 16, 2005 5:39 pm
i have a picture of a uprighted 5k from above if thats any help? i think i got it from www.rollaclub.com
PRESENT: KE35 Sr coupe (4agte project), GTS-T, MX40 Cressida coupe
EX:KE25 SL Coupe, KE30 4 door, KP61 4 door hatch, KE36 2 Door Wagon, AE70 2 Door Sedan, AE101 FXGT
ke_25
Postby z|gen » Mon May 16, 2005 6:41 pm
intake to carb ? or do you mean from the filterbox ?
you will also need a hose from the dissy to the carby..
AE91 SUPERCHARGED COROLLA
z|gen
Postby 1goodidea » Mon May 16, 2005 7:17 pm
z|gen wrote:intake to carb ? or do you mean from the filterbox ?
Nope not that one, it comes out of the front of the carb and goes straight down to a connection on the intake manifold, I'm sure it surposed to go from the carb to the dizzy but it runs ruff as like that
1goodidea
Postby Muzzie » Mon May 16, 2005 7:47 pm
Hopefully this helps.....
Mobile Car Servicing & Audio Installation - Inquire!
I'm Not Dumb, Im Just Selectively Observant!!!!
http://toyspeed.blakjak.net/profiles/pr ... hp?id=1036
Had flash sig, but too big for TS :(
Muzzie
Regular Poster
Postby z|gen » Mon May 16, 2005 7:47 pm
hmm..im confused, if your in welly and you havent solved it by the weekend, you can come round and have a look at my engine manuals if you want. just send me a PM
z|gen
Postby 1goodidea » Mon May 16, 2005 8:15 pm
z|gen wrote:hmm..im confused, if your in welly and you havent solved it by the weekend, you can come round and have a look at my engine manuals if you want. just send me a PM
Thanks the picture above is how i thought it should be, but it doesn't want to run smoothly like that
1goodidea
Postby z|gen » Mon May 16, 2005 8:28 pm
check your idle and fuel screws then...
z|gen
Postby 1goodidea » Tue May 17, 2005 8:56 am
OK i've fixed up the vacum hose and thats sweet,
Still having hesitation issue at low revs, and the other thing is frist thing in the morning when i pull the choke out and start the car it runs and then dies even though the choke is all the way out?
would that mean that my fuel mixture is either to rich or to lean?
1goodidea
Postby pervert » Tue May 17, 2005 9:02 am
Hesitant at low revs just sounds like a normal 4K if you ask me, they all seem like that until you pull about 2500-3500rpm...
pervert
Postby 1goodidea » Tue May 17, 2005 9:10 am
pervert wrote:Hesitant at low revs just sounds like a normal 4K if you ask me, they all seem like that until you pull about 2500-3500rpm...
hmmm anyone got any ideas on the choke problem as its' a biatch to start in the mornings!
1goodidea
Postby pervert » Tue May 17, 2005 9:43 am
Same thing with the choke, it is getting colder so just try keeping your foot down a bit for a minute or so before you rely on the choke to keep it idling...???
pervert
Postby 1goodidea » Tue May 17, 2005 10:49 am
It's like the choke is killing the motor, by stuffing up the mixture. hard to explain
Get in car, pull choke out turn key, no gas pedal
car starts then dies, start again car dies, turn key again car starts quickly put choke back in so motor doesn't die again and put foot on gas once again car dies.
Do the same thing again and it eventually starts, its not like the 2k where pull choke out, turn key motor starts runs mint
1goodidea
Postby moogoose77 » Tue May 17, 2005 1:11 pm
check the float level? it maybe quickly flooding itself or getting no gas at all..
moogoose77
Postby 1goodidea » Tue May 17, 2005 2:20 pm
moogoose77 wrote:check the float level? it maybe quickly flooding itself or getting no gas at all..
Hey thanks for the reply, whats a float level?
1goodidea
Postby Gx71man » Thu May 19, 2005 8:48 pm
just dont fully pull out the choke, pull it out slowly until its right, If that doesnt work, put in a 4age.
I Give My Mrs A 1/4 inch at a time, For those ten seconds or less Im Free...
Gx71man
Try this...
Postby drumma » Wed May 25, 2005 11:03 pm
Try this... Quarter choke, 2 pumps on the gas and start it up.
drumma
Postby Muzzie » Thu May 26, 2005 10:47 am
I don't use my choke at all. I just pump the gas once and then hold it on a lil til it starts.
It's a common problem that carby cars have when they are cold. Just idle it for a bit in the mornings before you go on to the road, it's a very sickly feeling to accelerate out on to the road and have it hesitate.
Muzzie
Regular Poster
