KE30/3k engine bay wiring help
Postby jeremiahnz » Thu May 26, 2005 10:54 am
I need help identifying where some plugs in the engine bay should go and what they are for. They maybe excess to requirements but if someone could confirm that, that would be great.
The plugs in question are circled in red in the pictures. Thanks in advance for any help!
Image Image Image
jeremiahnz
Postby pervert » Thu May 26, 2005 10:56 am
The right hand side picture shows the little green plug that goes to the factory carb, with my aftermarket carb on my 4K i've just got this disconnected and it goes fine.
pervert
Postby jeremiahnz » Thu May 26, 2005 11:03 am
Ok, so there should be a wire coming off the carb somewhere that plugs up to this.
cheers for that
jeremiahnz
Postby pervert » Thu May 26, 2005 11:26 am
Yup, as far as I can remember there should be one wire coming off the factory carb, thats where it plugs into, and it is the right hand side picture as well, sorry.
pervert
Postby LowNLost » Thu May 26, 2005 11:39 am
Bro , i got the exact same random plugs on my 3k . The green carby one is pluged in . but the other 2 just hang there , don't no what they do . but everything works sweet .
LowNLost
Postby l1ttle_d3vil » Thu May 26, 2005 7:41 pm
im not sure what the one on the left is for, its just left hanging there on mine too. the wire which goes into the other side of the plug (should be black/white I think) is for the warning light from memory. this wire hanging out is just connected to the ignition...thats all i know. doesn't seem to be used for anything specifically that i can remember.
Postby Virtual Genocide » Thu May 26, 2005 7:48 pm
Middle pic looks like its the thermostat temperature sensor plug.
I dont think the 1st one is for anything, its not used on my 4k anyway.
Phil
You can sum up the entire dream world of the motoring enthusiast in four words: "dont fence me in"
My Profile <----- check it out!
Virtual Genocide
