ke2# hub conversion?
Postby 3T-Rona » Sat May 28, 2005 10:22 pm
how do u convert ke2# hubs to kp6# hubs, is it as easy as swapping them over or is there more to it?
3T-Rona
Postby ke_25 » Sun May 29, 2005 2:18 pm
try www.club-k.co.nz forums.. theres heaps of info on there about changing them over..
PRESENT: KE35 Sr coupe (4agte project), GTS-T, MX40 Cressida coupe
EX:KE25 SL Coupe, KE30 4 door, KP61 4 door hatch, KE36 2 Door Wagon, AE70 2 Door Sedan, AE101 FXGT
ke_25
Postby crnkin » Sun May 29, 2005 5:47 pm
just bolt on bolt off dude.
Rear requires early model driveshafts- theyre slightly thinner, ive done it heaps, and know of many other people too.
sweet
deaf_homo "currrently yes"
crnkin
hubs
Postby KE20 » Mon May 30, 2005 12:44 pm
if you want to put bigger brakes and 4x4.5 stud pattern,i used ke70 then ae85, just by swapping the swing arms (so you get the bigger balljoint) bolt on the new strut and steering arm and change the top platform to ke2#, you also get wider track.
KE20
Postby 3T-Rona » Mon May 30, 2005 7:27 pm
cool, apart from wheels are there any advantages of having 4x114.5 over 100 or wotever ke2# stud is?
3T-Rona
Postby z|gen » Mon May 30, 2005 7:32 pm
disc rotor upgrades would be the major one for me,
AE91 SUPERCHARGED COROLLA
z|gen
