A few ae92 Qs
A few ae92 Qs
Postby Caveman » Wed Jun 01, 2005 4:41 pm
When removing the spoiler there are two nuts which you cannot access.
This view is looking down on the spoiler
How do you get these off?
Also where do you people run wires through the firewall. On my last car I ran it through the same hole as the loom but on my ae92 its a little harder to access. The wire is 12mm total.
AW11 Track Toy
Formerly known as 1998
Caveman
Postby Ae92typeX » Wed Jun 01, 2005 5:29 pm
On my ae92 levin the two you marked for the spoiler were actually ball clips, not bolts- a big pull and it came off.
I ran most wires through the big loom grommet on the passenger side wheel arch. once you take off the plastic wheel well cover its easy to see and get to.
I ran about the same size through for my amp.
Ae92typeX
Postby Lloyd » Wed Jun 01, 2005 7:48 pm
Pretty sure if you look hard enough you'll see where you can get to the nuts under the spoiler. Might be a bung or something over the hole to get at them.
As for the wire, just use the one for the loom from the ECU. I've managed to get 2 runs of 4ga wire through without too much trouble.
Postby Bazda » Wed Jun 01, 2005 8:44 pm
for the spolier its just a ball clip thing, just pull harder and it will come off or stick a screwdriver with some cloth over it to lever it off.
as for running wires through, I can most of mine through where the speedo cable goes through and the heater cable. You just take the gromet out and cut the centre hole out bigger.
Postby Caveman » Wed Jun 01, 2005 11:11 pm
Thanks for the imput.
The wire is to relocate the battery.
The spoiler is for looks... cos the foctory one is uhg :?
AW11 Track Toy
Caveman
