ChaosAD wrote:yes there is an idle adjustment screw. its down a hole on the top of the throttle body. may or may not have a cap covering it
matt dunn wrote:ChaosAD wrote:yes there is an idle adjustment screw. its down a hole on the top of the throttle body. may or may not have a cap covering it
To correctly adjust idle speed you must
first set the TPS correctly.
then set the
Ign timing correctly,
then you can adjust the
idle speed.
If they are not correct and not done in that order it will not be correct.
Matt
Karl_Skewes wrote:i always pull off the water stuff under the throttle and block it up.
warm idle about 200rpm higher then cold idle.
