on a twin turbo setup (for example, v6 2.5L vr4 motor
how does the BOV work? is there one BOV for each turbo or what?
these turbos are piddly little things btw!
Ae92typeX wrote:bov works off vacume pressure in manifold, so you just have one for the twins.
method wrote:Ae92typeX wrote:bov works off vacume pressure in manifold, so you just have one for the twins.
No i always thought they work on pressure in the manifold. Most cars have vaccume pressure in the manifold.
When the throttle body shuts they air being rammed in by the spooled up turbo has nowhere to go, where does it go? Out into the atmosphere (or plumbed back into the intake before the turbo) hence the louder psssttt noise at higher revs
stephen bedford wrote:am i not right or am i very wrong,and the srping is in the valve to push the cylinder back down when yuo put your foot up it again and open the throttle to stop boost leak,
