Piston or rotary...what to choose?
piston
49
64%
rotary
27
36%
Total votes : 76
Postby blackie » Fri Jun 17, 2005 3:54 pm
im sure however little rotarys produce in torque would be enough to get a car off the mark..
anyway, the car in question is a KE35 not an altezza.
do something out of the ordinary man..
how about putting a VTEC in? :lol:
blackie
Postby Mr Revhead » Fri Jun 17, 2005 3:56 pm
theres a kp60 here with a s2000 engine in it
hold on.. maybe integra engine, i forget :oops:
Postby THA SHZ » Fri Jun 17, 2005 3:59 pm
Mr Revhead wrote:
most of the top racers are rotarys
what? who? where?
australia and quite a few in nz too !
mostly in the draggin scene .
U cannot deniy that for wot it is and the brillance and fundamentals behind a rotary engine are not somewot interesting , intriguing and dam good for wot is considered a 1300 cc engine .
THA SHZ
Postby Mr Revhead » Fri Jun 17, 2005 4:04 pm
oh, the old 1300cc thing again... thats how they do so well in that class, a loophole!
they are effectily a 2600cc :wink:
now i know all the rotary fans are gunna deny that, but with the way they work, fireing cycles compared to output shaft revolutions they are 2600cc.
now compare them to a 2600cc fourstroke.. and things even up 8)
Postby flygt4 » Fri Jun 17, 2005 4:08 pm
hahaha age old arguments.... i still say 1uz is the way to go :D got gas axe?
flygt4
Postby rollas22 » Fri Jun 17, 2005 4:12 pm
Id have to agree here, a rotary engine is all or a 1200cc (12a) & 1300cc (13b) they produce a hell of a lot of power for what they are. Very well designed, and light.
The likes of a 13bt (turbo) would pull a altezza along quite nicely. Theres a lot of bmw's & merc's with rotary engine transplants these days... and they would be a lot heavier than a altezza.
More to the point its being DIFFERENT that gets you places in the car scene (show scene) these days.
Anyway the prices of rotarys is sky rocketing threw the roof!
The coments about there reliablity is a bit beyond a joke, they are reliable if they are maintained properly (just like any engine).
My little brother has a 12a Bridgeport KP60 Starlet - that hauls, and is so reliable... and will always hold its value! If it had a 4age in it, it would be worth 1/2 as much as it is with a tang in it! FACT
But more to the point, what to stick in a KE35, light coupe body shell. Its going to have a Hilux LSD rear end in there, so thats sorted, also larger brakes from a AE86 (possibly).... just need the engine so solve the puzzle.
So dnt get me wrong, i love toyotas having owned well over 20 of them... Maybe time for a change, but at least it will still be a toyota with *maybe* a slight engine transplant....
KE-Corolla's for life!!!
rollas22
Postby flygt4 » Fri Jun 17, 2005 4:17 pm
im sure a lot of people would have suggested a 4agte rollas22 but seeing as you've just come from down that road i can see why you want something a little different.
flygt4
Postby Mr Revhead » Fri Jun 17, 2005 4:20 pm
how about a 2rze? torque for africa, and DEFINITLY different
Postby blackie » Fri Jun 17, 2005 4:37 pm
2rze.. had never heard of that..
so its a 2.4L hiace engine?
z = supercharged?
crazy
blackie
Postby Mr Revhead » Fri Jun 17, 2005 4:39 pm
yeah 2.4 hiace
no not s/c
2rz-e is how it should be also a carby version 2rz
Postby Xyrath 86 » Fri Jun 17, 2005 4:54 pm
Just 2ZZ it, its different and just plain cool and fast for n/a.
Xyrath 86
Postby bogjob_kp60 » Fri Jun 17, 2005 6:35 pm
Mr Revhead wrote:theres a kp60 here with a s2000 engine in it
What about a fully worked 2k :lol:
Yip iv seen that one somewhere 8O
bogjob_kp60
Postby event2 » Sat Jun 18, 2005 1:00 am
14.5hp brigs and stration out of MTD ride on
1991 gtz trueno "HELL YEA" 4 sale (sold and i miss it so)
event2
Postby Alex B » Sat Jun 18, 2005 1:51 am
1gz-fe :D
Postby Gx71man » Sat Jun 18, 2005 7:44 pm
Mr Revhead wrote:yeah 2.4 hiace
no not s/c
What does the 2rz-e come in?? the rzh113 type is carb.
Lol 3rz-fe!!!! they go hard as, second hand ones are only $1000-$1200
I Give My Mrs A 1/4 inch at a time, For those ten seconds or less Im Free...
Gx71man
Postby Mr Revhead » Sat Jun 18, 2005 8:24 pm
rz hiace was carb and efi
Postby Muzzie » Mon Jun 20, 2005 3:40 pm
Piston Power!
Mobile Car Servicing & Audio Installation - Inquire!
I'm Not Dumb, Im Just Selectively Observant!!!!
http://toyspeed.blakjak.net/profiles/pr ... hp?id=1036
Had flash sig, but too big for TS :(
Muzzie
Regular Poster
Postby RomanV » Wed Jul 06, 2005 6:01 pm
Well designed.. Yes.
Light? Hell no. :lol:
eg. a guy swapped his rotor out for a v8, and his car gained 40kgs.
They area a very COMPACT engine, but its mostly full of metal. Whereas a larger v8 looks heavier, but its full of air comparitively. 8)
Although Im not sure of specific weights, I have been told that rotaries are deceptively heavy. Especially if you could swap it for an alloy block engine.
I dont see why so many people harp on about rotors so much. I mean NA rotors are pretty average really.
You get bugger all power unless you port the shit out of them, and then they run like crap below 5,000rpm. :?
Ive seen a few dyno plots of tuned NA rotor motors, and wasnt very impressed at all. :?
If people spent as much money on say a 2 litre NA piston engine as they did on an NA rotor, they would probably make just as much power IMO.
Infact I bet some modern variable valve timing motors are making the same sort of power, with superior low/midrange torque.
But I would say that. 8)
But you cant get a piston motor to go BRAP BRAP I suppose. :lol:
I think the reason they are called '1300cc' is because thats what you would think you are driving, at low RPM. :lol:
In saying that, one of my mates used to have an RX2 that was built by PAC performance in Aussie. It had big $&#$% off disc brakes all round, a diff out of a Mazda bongo van, and it revved to about 12,000RPM! 8O
That was a pretty crazy car! 8O
IMO: an original engine for a KE? A turbo charged hyabusa engine or two. :D
Postby Mr Revhead » Wed Jul 06, 2005 9:22 pm
hehe yeah twin hyabusa mmmmm
and yeah, rotors are fecking heavy. one sat in the boot of my old bluebird for 2 months, permantly lowered the rea 2-3 inches 8O
Postby Dell'Orto » Wed Jul 06, 2005 11:52 pm
RomanV wrote:eg. a guy swapped his rotor out for a v8, and his car gained 40kgs.
Dont know how many times I've had to repeat this, but a 13B with oil, and all ancillaries bar exhaust manifold weighs 130kg. I had one shipped to me on a pallet, they're not that heavy. Two of us lifted it off the back of a ute.
Return to Polls
