idle motor
idle motor
Postby blue-smoke » Fri Jun 17, 2005 8:16 pm
my idle motor is $&#$% or thats what i have been told on my mr2 (4agelu) and im not to sure how to find it or how to fix it aye , when i stop my car and leave it running it will idle at 2 grand and sometimes 1 and a half grand and then will go up to 2 grand and back down to one and a half ... etc, any assistance in this matter would be greatly apperiated
blue-smoke
Postby Alex B » Fri Jun 17, 2005 8:30 pm
hmmm i viewd a old pop up light integra yesterday with the same fault. Is it just when it heats up or is it an all the time thing?
Postby RedMist » Fri Jun 17, 2005 9:42 pm
Sounds more like a vacuum leak.
I didnt think the 16 valves had an idle control motor?? Don't they use a wax pallet for cold start idle? (I dont have cold start on my race motor, so cant help much)
The answer is Helmholtz!
Toyota ST185 Celica Rally.
Toyota ST205 Celica Rally.
RedMist
Postby ants_ae92 » Fri Jun 17, 2005 11:46 pm
Yeah you are right redmist, they use a wax pellet type. Could be a vacuum leak, or it could be that the valve is stuck, and the cold air idle valve is open all the time. The computer will cut the injectors to stop the over revving.
Try for vaccum leaks with some engine start.
The wax pellet, is underneath the throttle body. You will see 2 water pipes that go into it. That is it. Fixing it costs alot, $180 from toyota (pm mr revhead), or try getting a second hand throttle body. But you don't know if that one is stuffed as well.
http://toyspeed.blakjak.net/profiles/pr ... hp?id=1548
Current Ride: ae101 1997 White corolla BZ-touring station
Previous Rides: ae92 Levin (smallport 4age, Lowered, 17s, exhaust, intake). Ke70 Station wagon (4k, lowered)
ants_ae92
Postby blue-smoke » Tue Jun 28, 2005 9:32 pm
yeah its all the time , what will happen is that it will ideal at 2 then at 1 and a half then at 2 ..... etc , yeah i will check that out
blue-smoke
