KE35 mag offset.
KE35 mag offset.
Postby SIKTOY » Sun Jun 12, 2005 1:12 am
Hi there, Im sure someone has asked this before but I havent been able to find a definate answer.
Im looking at putting 15's or 16's on my SR with 195 tyres and I was wondering if anyone out there knows what the correct offset is that I need.
Is there anyone who has got / had 15 or 16's with 195 (or bigger) tyres on a KE35 etc who knows what offset mags they used.
It will be approx 50mm lower all round and I want the wheels to fit within the guards without any rubbing problems etc.
Im really after the number not vauge answers but any help would be appreciated.
Cheers guys and girls!
ALL MEN DIE, NOT ALL MEN TRULY LIVE!
Current: 80 SR Project,
Check Out My Profile, Including CURRENT Pics!
Previous: 90 GT Sedan, 85 FXGT, 77 SR with 18RG, + many more.
Pink shaved pussy pic!!!
SIKTOY
Postby Rob_GTZ » Sun Jun 12, 2005 10:45 am
As low as possible, and nothing higher than +25
Rob_GTZ
Postby suberimakuri » Sun Jun 12, 2005 8:56 pm
don't run 16s.
run 15s, and you can fit 6.5jj +10 at least on the front, and 7.5jj + 25 on the rear.
remember, hotwires which are about 7jj +5 13" fit on these.
suberimakuri
Postby SIKTOY » Mon Jun 20, 2005 7:10 pm
Cheers guys,
Now I know what to look for. :P
SIKTOY
Postby RE20 » Mon Jun 20, 2005 10:17 pm
Karl_Skewes wrote:don't run 16s.
Whats the jj mean? :oops: And would the same offsets apply to a KP starlet?
In the event of nuclear catastrophe, the only survivors will be Cockroaches and Toyota K series engines...
pervert wrote:Haha, it's not low enough, it still has suspension travel!!!
RE20
jj
Postby SIKTOY » Tue Jun 21, 2005 10:31 am
Dunno what jj stands for but its the inside width of the rim.
eg 6.5jj = 6 and a half inches wide from the inside of one rim wall to the other.
As to KP spacings, dunno. but im sure someone out there can help you on that.
SIKTOY
Postby RE20 » Tue Jun 21, 2005 6:32 pm
bump
RE20
Postby ke_25 » Wed Jul 27, 2005 6:09 pm
so would fwd offset fit on teh rear on a ke35? and have spacers on teh front? or would need hub adaptors?
PRESENT: KE35 Sr coupe (4agte project), GTS-T, MX40 Cressida coupe
EX:KE25 SL Coupe, KE30 4 door, KP61 4 door hatch, KE36 2 Door Wagon, AE70 2 Door Sedan, AE101 FXGT
ke_25
Postby TygerTung » Wed Jul 27, 2005 11:37 pm
Wont fit on the front, will fit on the back, but looks RUDE as because the wheel sits MILES inside the guard.
TygerTung
Postby ke_25 » Thu Jul 28, 2005 11:37 am
so would need set of 4 hub adaptors made up to get the wheels in teh right place?
ke_25
Postby TygerTung » Thu Jul 28, 2005 11:10 pm
Yes, also you need cert, or just put the standie wheels back on for a wof
TygerTung
Postby ke_25 » Fri Jul 29, 2005 3:59 pm
yer.. myte just keep teh hotwires.
ke_25
Postby drftnmaz » Mon Aug 01, 2005 10:47 am
the correct offset is "20"
drftnmaz
Users browsing this forum: Bing [Bot] and 23 guests
