Akane wrote:All MR2's can go past 180kph, fuel cuts near around 200kph mark.
did you just change the face on your speedometer to a 300km/h one? You're probably only doing 150km/h at 210
CozmoNz wrote:seems silly eh?
5,000rpm in 5th gear at full throttle, and it makes you run lean? thats an expensive top speed run...
fivebob wrote:CozmoNz wrote:seems silly eh?
No, it's 5500rpm in every import MR2 I've driven and it doesn't make it run lean, no fuel = no combustion.
And to answer the original question, the 300km/h speedo removes the limiter, so I don't know why you could only do 180km/h before.
streatracer wrote:is there an easy way to get rid of limiter?
CozmoNz wrote:5k rpm was a rough example, i was just saying, high rpm, high load condishions etc whatever, you knew what i ment!
Al wrote:fivebob. I seem to recall on the TRD site that the speedos on offer had *does not remove 180km/h limiter* printed under the details of the speedos. Or is the mr2 one different?
