injector size,
fuel pressure,
injector duty cycle,
and air velocity into the combustion chamber.
I was thinking 'why dont all cars run big injectors?'
Obviously if you increase the injector size, you have to reduce the injector duty cycle to acheive the same A/F ratio.
So whats wrong with doing this?
Is there could be a point where you reach a duty cycle percentage that is too low?
eg. The fuel would come out in large bursts with a long interval, rather than smaller, rapid bursts. So the fuel is not mixing with the air as well, leading to a less powerful combustion. Even though the same air/fuel ratio is being acheived.
So, I suppose my long winded question is this:
Do large injectors have a detrimental effect on performance/economy as outlined above, and is this the reason some tuned cars run out of injector duty cycle on standard injectors?
OR is there a much more simple explanation for why cars dont run big injectors from the factory.
eg. Larger injectors are more expensive.
