by Rollux » Thu Jul 07, 2005 10:43 pm
What we do at work(with engine in or out) if it's bad is take the rocker cover off, the sump off and use a steam cleaner to clean it all out. Cleans all the oil galleries etc, and the main buildup. Then fill with oil and engine flush, run for 15 mins, drain & refill with oil. Great way to clean SR engines
2002 Allex RS180 6 Speed
Nissan Motorsport = Nismo
Honda Motorsport = Homo??
