Look at my orioginal post and you'll see that I'm fitting forged pistons soon
While the engine is apart, will also be looking at how the head flow can be improved.
It is a genuine NZ new WRC so has steel internals. Could well be that the turbo needs pulling out an inspecting if it's taking so long to spool up compared with what you say above.
You can see the bonnet spoiler in this pic...
Apexi FC ECU is on the shopping list for when the rebuilt engine is run in. Set up will be done on the dyno to ensure fuelling is as it needs to be - so if a bigger pump/injectors are required, then so be it.
While money isn't endless (I still have the rally car build to consider
), I do realise decent power can't be obtained with just a few $.
As said earlier, I am a newbie to Toyota mods, so please take this into consideration when posting. I am not a teenage 'dreamer' (though it'd be nice if I were 20 years younger
Gary
