TWSTD wrote:Im pretty sure my ST215W manual is an open diff as well - I can very easily get one rear wheel spinning when going up my car park ramp daily...
No, the manual is most definitely LSD. The Torsen style LSD isn't a full lock-up type of diff and can only bias the torque to around 80/20, so it's still possible to spin one wheel in situations of very limited grip.
FYI as far as the ST215 goes, all GT's had LSD, all Manual GT-Ts had LSD, the rest were open. you can check the specs for yourself at http://english.auto.vl.ru/catalog/toyot ... na/1997_9/
I also seem to recall the old TRD part no's for the ST215W rear LSD and the ST205 rear LSD were the same no's.
Indeed it was, and it was a clutch pack diff, so full lock-up was possible, sadly though it's now a discontinued item.
